585,930 active members*
3,715 visitors online*
Results 1 to 14 of 14
    May 2009
    327
    Weird Mach issue
    I had a very weird issue today. I did a toolchange and when I went to start the spindle didn't start. So I stopped the program and I could turn on the spindle from mach. I went to cut again and then the Y didn't move. Luckily I caught it before I messed my part up. So I restarted mach and everything worked. Then the spindle wouldn't start again. So I played with it and the spindle would sometimes turn on. So I am thinking it is the bob or the smoothstepper which would bum my whole day out. So I get it not to start and I press the diagnostics tab and the spindle starts. So I press the program button and it shuts off. Back and forth and the spindle will start when I get off the program tab. So I now think it must be mach doing this. I went back and forth a bunch and every time it did it. I shut down and restarted and I was able to finish my cut.
    So I am assuming I should reinstall mach correct? Can I just install on top of it? Does it wipe out my tooltable and machine definitions?
    Any help would be appreciated!
    -Keith
    Aug 2007
    701
    Re: Weird Mach issue
    I had all sorts of weirdness with Mach even after reinstalling. I switched to pathpilot and am in love with it.
    Jun 2014
    777
    Check the Mach setup config file for duplicate settings. Mach 3 has a tendency to corrupt itself by duplicating its own settings.
    Jun 2004
    6618
    Which BOB do you have on it? I had some issues similar to that with the old style BOB on the Pulsar.
    Mach 3 glitches are very rare with the newer Arduino Bob.
    Lee
    Jun 2014
    777
    Quote Originally Posted by LeeWay View Post
    Rare, hmm 3 reinstalls in 3 months was the last straw for me.
    Jun 2004
    6618
    Don't get me wrong. Glitches still happen with Mach 3. We snapped a drill bit the other day for no reason at all other than Mach 3 forgot to use the tools offset from the table. It had been using that bit fine all day and continued to use a replacement fine afterward. No excuse other than being unreliable. That is the cheapest tool that it could have broken, but still it would have caused down line failures with taps etc if it were on an atc.
    I have been watching the Path Pilot thread with interest.
    Lee
    May 2009
    327
    I have a relative new bob. Not sure on the version but it is the audrino. I will check the config file first and then I guess reinstall.
    Am I going to lose my tooltable if I reinstall?
    Thanks guys!
    -Keith
    Jun 2004
    6618
    I always copy the entire folder as a backup.
    That's not really necessary, but it works well for me.
    It should not overwrite the tool table, but......it is a rebel of a piece of software. Always doing what it shouldn't.
    Lee
    Try using a backup .xml file from the xmlbackups folder, from a few days back when it was working fine.
    When it is working fine, make a copy of the .xml.
    My Mach3 install has been fine for 7 years, but the .xml file went bad twice.
    May 2009
    327
    Well I went down to cut some stuff tonight after reinstalling mach and the computer was acting weird. Probably should have checked to make sure the keyboard didn't have crap in it that was causing a keystick. Whoops!
    -Keith
    Jul 2011
    400
    Quote Originally Posted by keithmcelhinney View Post
    -Keith
    This one might actually not be a whoops at all. My computer will often mimic a sticking key. I first noticed it while jogging. After releasing the jog keys it would continue at full speed until it hits a limit or I hit the escape key to stop it. Of course this process makes it lose sync between the position and where it thinks it is. So I would have to re home and to be sure I would reset the work offsets also. This frustration would continue for some time. Eventually I learned if the key appears to stick it will continue at random times. I learned to just shut down mach and restart it. The problem is then gone for a while at least. The good news is this problem shows up during setup before a cycle is started.
    I find mach to be buggy and weird. For example today I was doing some tool path testing as I will need to make a tooling plate. I made a row of 7 holes. I drilled through with a 1/4" drill then followed up with a 1/4" end mill to bore the holes to size. 6 were good plus or minus a thou. One however was .005 undersized. I don't know if I should blame mach or the cad. I think I'm going to start paying more attention to the Path Pilot thread.
    May 2009
    327
    I definitely know it was my keyboard. I opened notepad and it just started filling it up with"aaaaaaaaaaaaaaaaaa..."
    I have noteced that if you get a popup in mach and use the jog wheel it will keep running even after you stoped turning the wheel. Same thing if you are editing the Gcode in notepad while joging.
    Made By Viklund
    Jul 2011
    400
    Quote Originally Posted by MBViklund View Post
    I'll have to pay attention to this next time it happens. I only use the mach jog wheel for switching only. For example switching from step to continuous. I use the actual keyboard for jogging. I'm looking forward to the arrival of a pendant.
    Tom
  1. weird sync issue with mach 3 and tb 6560 driver
    By miniarcade in forum Mach Software (ArtSoft software)
    Last Post: 02-12-2015, 03:20 AM
  2. Weird 4th axis issue. . .
    By brianbonedoc in forum Novakon
    Last Post: 02-07-2015, 01:23 AM
  3. Weird window size issue with KMotion CNC
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-13-2014, 12:33 AM
  4. Weird issue with NC output
    By ClockMaster in forum FeatureCAM CAD/CAM
    Last Post: 12-19-2007, 11:21 PM
  5. Weird stepper issue...
    By WilliamD in forum Stepper Motors / Drives
    Last Post: 07-21-2006, 05:11 PM
