Hello, i use a Haimer ( pls see attached photo ), that has 3mm range
This watch arms at the middle of the range, 1.5 mm, and i was wondering if you know watches that arm just a bit, ~0.2 for example ?
Asimeto version ( pls see attached photo ) seems to have a fine adjustment ... does anybody know if this one arms just a bit, and not at middle-range ?
[ Middle-range arming ] + [ watch retreat and reenter ] = [ palpator broken ]
Of course, you can arm just a bit using a pupitast ( pls see attached photo ), but their range is short ( ~0.8 ), and if missalignment is >0.8, than you put extra-force on internal mechanism.
Centro Watches have greater range, while pupitast allow soft-spring-arming. I need a combined version please
