585,712 active members*
4,240 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Quartz Counter top for Mill Base
Page 3 of 3 123
Results 41 to 48 of 48
  1. #41
    Jun 2010
    4256
    Re: Quartz Counter top for Mill Base
    I will admit to having some considerable reservations about relying on deliberate distortion to get a flat surface. I would prefer to get someone to polish the surface FLAT at the start.
    My bias.
    Cheers
    Roger.
  2. #42
    Dec 2013
    33
    I have some reservations myself Roger but this build is about finding out what can be done and if I screw it up someone else can learn from it. The latent stresses were more of a concern before I read about prestressed concrete. Basically steel rods are put under stress so the concrete is preloaded which improves the strength. Wikipedia has a good article about it. So the main thing I am concerned about is creep over time were my machine becomes more and more relaxed causing it to move. I have done the carbon fiber coating on the backside of the X axis gantry to lock the gantry in place as much as possible.
    Attachment 355772
    I am using 20 layers of carbon in the short side with flat being covered with 8.
    Attachment 355774
    I then covered the ends where it will attach to the z axis riser with peal ply so I won't have to do any post layup sanding, just pull the peal ply and add additional layups.
    Going back to my setup I bonded 1/8" x 3/4" angle iron to the side of the gantry. I will use this to push against for correcting my flatness. This was then covered with JB weld on the outside to prevent any galvanic interaction with the carbon fiber. Probably not as big a concern as the aluminum inserts but I am doing everything I can to prevent it.
    Attachment 355776
    You can see where I have coated the angle iron and if you look at the edge above it I used a flapper wheel on my angle grinder to put a radius on it so that the carbon layers would not lift.
    Attachment 355778
    I covered the angle iron with peal ply to keep from having to do a post cure sanding. This worked great.
    Attachment 355780
    The holes were filled with paper and then taped to keep as much epoxy from filling the holes as possible. Post cure, I will drill the carbon layer out to reveal the holes.
    The next step will be to fabricate the jack screw plates, (22) required, and mount them. Next is another dry run to see how close I can get to 0.0001" flatness.
    If I can get the flatness but I have creep then I will hone the linear rail surface flat.
    Thanks for reading, more to come.
  3. #43
    Jun 2010
    4256
    Hi Keffer
    No problems at all about running the experiment. Experiments are always good. (Professionally I am an experimental physicist.)
    My wondering is about the material. Is this synthetic quartz (ie made with some sort of resin) or natural sawn quartz?
    Hum - natural granite is widely available, but natural quartz in blocks? I dunno.
    Anyhow, we do know that natural granite can be amazingly stable. I believe high end CNCs use it sometimes.
    Cheers
    Roger
  4. #44
    Dec 2013
    33
    Hi Roger
    The material that I am using is a man made quartz with a resin binder. This web site https://www.msistone.com/quartz-tech...pecifications/ has some good information about the material.
    The web site has done testing on the material https://www.msistone.com/download/Qu...ifications.pdf if you would like to see that.
    I was interested in the epoxy granite thread and this material is a factory made version of this. I originally was planning on using aluminum but even using pieces from the local Alro supply was going to be $3.00 a pound. While shopping for counter tops with my wife I found a local supplier with pieces of quartz counter top left over from jobs for $10 a square foot. I took a few samples and found it was fairly easy to work with. I then modified the design I was working on to use this material. So the good is that it is cheap and weighs less than aluminum and has better vibration dampening than cast iron. The bad is it has 1/3 the bending strength of aluminum. I ran a stress analysis with carbon fiber covering the quartz and was impressed with the results. My plan is to check results with reality when the current layup has had time to set. I don't know this yet but my guess is that the larger the piece the more the carbon fiber will help. So that's a summary of how I got where I am and what I know about the material. I will continue to post my results good or bad.
    Cheers to you.
  5. #45
    Jun 2010
    4256
    I should have Googled first. But offcuts - neat!
    Have you though of adding stiffening ribs underneath, with epoxy and bolts to join them? Just wondering.
    Cheers
    Roger
  6. #46
    Dec 2013
    33
    It has been cold in Michigan so I have let the composites sit a bit and worked on the design and frame construction.
    Attachment 357240
    I don't like sweeping chips so I have designed in a tray, shown in blue, to collect everything that falls down the chutes.
    Attachment 357242
    Here is the frame with the chip tray in place. I am using 4" steel v wheels riding on angle to track inside the frame. I still need to finish the design for the end but it will be two wheels riding on the concrete.
    Attachment 357244Attachment 357246
    I am using 1" square tubing x 1/16" for the scrap tray frame. I found some 7/8" key stock which I pressed into the support brackets so the frame could slip together/apart when I need to work under the machine.
    Attachment 357248
    I will have a 2" gap all the way around the perimeter to allow chips to fall into the chute. Hopefully this keeps things clean.
    Attachment 357250Attachment 357252
    The green way covers will help move the chips to the tray. I am attaching them to my table so as it moves back and forth the chips will move to the end scrap chutes. I am using springs to attach the two ends together (see bottom view).
    By the time the frame is done it should be warm enough to go back to the composites. I hate heating the shop to 75 when it's in the 20's outside.
  7. #47
    Dec 2013
    33
    Haven't posted in awhile but I have been working. I switched to the mechanical components while the weather warmed and have completed some of the way cover roller mechanism.
    Attachment 360674
    Rendering of the way cover roller assembly
    Attachment 360676
    Plates are complete and I am working on the bearing spindles.
    Attachment 360678
    The steel frame and guards are mostly complete but I still need to weld in angle iron hold down for the quartz sub table.
    Attachment 360680
    I need to tap the inserts in the end pieces and then I will bond the sub table together on my surface plate. Missing in this picture are stub pieces that will go between the outer and inner plates. When all are bonded the sides will be covered with eight layers of carbon fiber.
    Attachment 360682
    Rendering of table reinforcement without top plate.
    I plan on getting the sub table completed and then I can paint the frame and move the mill into its final location to anchor it down. At that point I can level and bond the table top to the sub frame. The linear ways bolt to the table top.
    Thanks for following.
  8. #48
    Dec 2013
    33
    Attachment 361278
    This is my setup on my surface plate. The table mounting surface is face down. The right side is my master side and I used two blocks for spacers for distance and squareness. The dimension between the to outside surfaces with the blocks was within 0.5mm of the design dimension. The only real critical dimension is between the two inner rails. I used the 12" calipers to set that dimension, worked well. The third rail from the right is held square with the large square. I want these surfaces dimensional correct and straight because I will mount the angle iron piece for jacking the table surface straight there. Bolts will be threaded up into the linear rail mounting inserts to pull the table down. Holes will be drilled between those holes to jack the table up. More to come on that when I mount the table.
    Attachment 361280
    I applied JB weld to both the end piece and the rails.
    Attachment 361282
    Used a stick to radius the corners. I will have to add chopped carbon fiber and epoxy to make the radius larger before the fabric is applied.
    Attachment 361284
    This is my dad giving me a hand with the project. He turned 85 last week. Thanks for the help Dad.
Page 3 of 3 123
  1. Replies: 1
    Last Post: 06-11-2014, 02:53 AM
  2. Mill Drill Z axis Counter Weight
    By Need TECH Help! in forum Benchtop Machines
    Last Post: 12-03-2011, 10:32 PM
  3. COUNTER BALLANCED MILL HEAD
    By letmefixit in forum Charter Oak Automation Support Forum
    Last Post: 03-30-2010, 05:18 PM
  4. Machining Astro-Quartz
    By JB F4 1000 in forum Composites, Exotic Metals etc
    Last Post: 08-29-2007, 02:24 AM
  5. Quartz filled epoxy...
    By karmicthre in forum DIY CNC Router Table Machines
    Last Post: 06-22-2004, 02:30 PM
