585,951 active members*
3,895 visitors online*
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Feb 2015
    Re: BootstrapCNC Router Plans
    This looks like very much what I was looking for.
    My sole issue with the design is making the rails adjustable, and not the bearing holders. Adjusting the rails and not the bearing holders depends on the bearing holders being identically spaced at both ends. This is fine if there's an eccentric bolt or similar mechanism to make that adjustment, but as is, it seems to me that a slight misalignment with the skate bearings at either end could result in a potential wobble in the gantry which would introduce tolerance errors.
  2. #22
    I have built 3 of this design so far and haven't had any issue with the bearing being non-adjustable. When making the bearings I used spacers and scribe into the aluminum and then use an automatic center punch to place a divot to mark the hole position. After making all of the bearing assemblies, I place them on one of the rails and make sure the ends line up, matching up pairs that align, if any do not align, I make an additional bearing assemble that does line up. So far I have only had to make 1 additional bearing assembly on 2 of the machines.
    I also use a spacer to ensure that the space between the mounted bearings is consistent. What I have found is that given that we are dealing with wood any spacing issues must be lost in slight flexing of the wood when adjusting the rail spacing.
  3. #23
    Jun 2018
    I'm just gonna say, new here, but so far possibly the best plans I've seen for building without any weird impossible to get components or tooling needed. I hope I can start a build thread before the end of 2018.
  4. #24
    A lot of work went into making the plans, and there are a few things I have learned helping build a few more of the machine that I need to add to the plans. I also have a variation in mind that might make the gantry a bit easier to build, but I need to test it out before I change the plans. I haven't been actively building much lately, hoping to change that soon.
    Please let me know when you start building and I if I haven't updated the plans by then I will try to let you know what needs to change.
Page 2 of 2 12
  1. Does anyone have plans for this CNC Router
    By 94vette in forum DIY CNC Router Table Machines
    Last Post: 08-13-2010, 12:48 AM
  2. Looking for plans I used for CNC Router
    By Kraig1 in forum Open Source CNC Machine Designs
    Last Post: 09-07-2009, 06:03 PM
  3. Plans for a CNC Router
    By DAB516 in forum DIY CNC Router Table Machines
    Last Post: 03-30-2007, 08:00 PM
  4. My CNC Router Plans
    By Clyde in forum DIY CNC Router Table Machines
    Last Post: 04-18-2004, 04:32 PM
  5. New 4 X 8 Router Plans
    By ninewgt in forum News Announcements
    Last Post: 09-14-2003, 05:59 AM
