585,914 active members*
3,756 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Ultimax 2 CRT Graphics Monitor Retrofit
    Jun 2011
    6
    Has anyone ever retrofitted the graphics monitor using a standard PC CRT or LCD Monitor. I have an older BMC-30 with Ultimax 2 Controller. I know you can purchase monitor replacements but the $1200.00 - $1500.00 price is a lot of money. It seems to me it should be possible even though the connectors are not standard on the Ultimax 2. Any feedback would be greatly appreciated. Someone must have figured this out and came up with a wiring diagram or procedure.
    Feb 2006
    174
    Re: Ultimax 2 CRT Graphics Monitor Retrofit
    Well, you have probably read my prior post "Ultimax Text Monitor Repairs ".
    Been there , done that. My solution was to stay with what I had
    The company up north seems capable of changing to LED, but the cost ( 1200-1500) was over my budget. They did offer the technical support it seemed .
    I found some suppliers in MO and TX that seemed capable at 500 $ , but neither had specifically changed a Hurco Ultimax II screen - that left me with a nervous factor
    The Text screen is a special frequency Monochrome screen ( 15+ K HZ ~) and the graphics screen is a more common RGB ( 16+ K HZ ~) running monochrome screens.
    The above may be in error as info, but it is what I remember when I looked.
    The Text also has a 5 pin feed and not 9 pins which seems to be a standard of some sort.
    So yes, I would think someone has done this, but none that I was able to find 2 years ago
    Rich
    Jun 2011
    6
    Thank you for your response. It is only my graphics monitor that I need to change. It hasn't worked in a few years and was never a problem except now I have a need to engrave and it cannot be done without the graphics screen. I have looked at using an arcade card to convert to a LCD monitor, but have an older Dell CRT monitor that was never used and would seem to be an ideal candidate. I just lack an understanding of the video signals and where what wire goes.
    Chris
    May 2012
    17
    Retrofit LCD Monitors from 7" to 15" under $600. CNC Industrial monitor repair service.
  1. Ultimax replacement graphics screen
    By tallenttoolroom in forum HURCO
    Last Post: 04-17-2023, 12:06 PM
  2. Ultimax Text Monitor Repairs
    By Rich Carlstedt in forum HURCO
    Last Post: 09-10-2014, 11:26 PM
  3. Why is the graphics screen doing this? KM3P Ultimax II
    By pondringjunkman in forum HURCO
    Last Post: 12-23-2012, 01:01 PM
  4. need help to retrofit skm edm cga monitor
    By rusty abe in forum EDM Discussion General Topics
    Last Post: 12-03-2011, 06:12 AM
  5. Ultimax 3 twin monitor
    By BustedKnuckle in forum HURCO
    Last Post: 09-07-2010, 09:31 AM
