I need advice, I have this machine at my disposal and I am marking stainless steel I am having trouble (mainly with the software and the setup).
I am writing text and the parameters I can change are;
Power (pretty self explanatory)
Frequency (I understand the concept but I don't how it affects the mark other than the darkest mark I achieve at ~22.5khz)
Rate (this is the speed the laser travels across the material in m/s)
Laser pulse width (no idea default is 4 - 200nm)
Laser parameter recipe (no idea what it does but it is greyed out and the option selected says custom)
Pulse width (no idea)
Wobble width (this controls the width of the text in mm and the stepover for each pass (it passes in a moving spiral))
Wobble frequency (default is 1)
My main problem is that I cannot get a 1mm wide text with a small stepover (~0.02mm).
Does anyone have any experience with this software or laser marking in general as I am in over my head and could really use the help.
