585,974 active members*
4,318 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LT10 OSP 7000L
    Feb 2016
    7
    Hi All
    I have an Okuma LT10 7000L, in the last few days it has been alarming out. It will alarm out when running and not running after about 20 minutes
    Alarm code 1208 BDU overload, when I check in the book it tells to check slave station 13, which I have done but I don't know what i am looking at.
    The first image is before it trips
    The second image is after the alarm triggers
    Can anyone tell me what i should be looking for.
    Apr 2009
    1262
    Re: Okuma LT10 OSP 7000L
    Your axis drive unit is overloading. Check your axis loads to see if they are unusually high. If they are, check for something restricting axis movement such as packed chips, binding covers, etc. If the loads are not high, check to see if the BDU fans are functioning. If they get gummed up and stop, this alarm will also occur.
    Best regards,
    Experience is what you get just after you needed it.
    Feb 2016
    7
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    Thanks, i will check all the fans and slide ways are clear.
  1. Replies: 4
    Last Post: 10-05-2014, 04:14 PM
  2. Okuma OSP 7000L ALARM 352
    By bobancurug in forum Okuma
    Last Post: 08-25-2011, 12:04 AM
  3. Okuma LT10-m
    By age_cph in forum EdgeCam
    Last Post: 04-28-2011, 10:26 AM
  4. OKUMA LT10
    By clp_00 in forum CNC Machining Centers
    Last Post: 07-10-2008, 09:22 PM
  5. Replies: 6
    Last Post: 12-03-2007, 01:32 PM
