585,741 active members*
5,159 visitors online*
    May 2010
    LinuxCNC 2.7.3 G0 Z0
    Running Ubuntu with LinuxCNC v2.7.3. Nothing else running on the Dell.
    Sometimes when I "G0 Z0" LinuxCNC goes to Z 0.1 ( metric). It also then goes to clearance at 10.1 when the gcode specifies 10.0 and any gcode specifying a z level is then always out by +0.1.
    To solve the problem I have to restart LinuxCNC and go through homing and re-check x, y and z touch off again.
    I thought it might have been caused after a re-touch off on z so I tried to reproduce the problem this morning while air cutting but it didn't fault either at a fresh start or after 30 mins of warm up.
    Anyone else had this problem or know what could be causing it.
    Thanks in advance.
    Graeme
    Sep 2010
    84
    Re: LinuxCNC 2.7.3 G0 Z0
    Are you viewing the actual position or the commanded position?
    JT
  1. LinuxCNC 2.7.1
    By kstrauss in forum Tormach PathPilot™
    Last Post: 10-18-2015, 08:21 PM
  2. LinuxCNC?
    By MBViklund in forum Novakon
    Last Post: 01-29-2015, 06:33 AM
  3. Linuxcnc 2.6.0 is out.
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 07-30-2014, 03:13 PM
  4. Linuxcnc 2.5.2 won't run
    By cpeter in forum LinuxCNC (formerly EMC2)
    Last Post: 04-24-2014, 12:54 PM
  5. LinuxCNC right for me?
    By punisher454 in forum LinuxCNC (formerly EMC2)
    Last Post: 06-18-2012, 04:56 AM
