Been lurking on this forum for a little bit since I picked up 1100 late last summer. Just wanted to share a few modifications/upgrades that I did to mine for the knowledge-base.
I did an enclosure on the cheap using steel pipe, fittings, and clear shower curtains that I cut down. Cost about $70 for the frame from the big box store and another $15 for the curtains and hangers.
Its definitely saved me a bunch of time with cleaning and also allowed me to go full flood coolant. I would like to go full hard sides in the future but am still in the design phase of how I want to do it. In the mean time I get an occasional leak in the front if I don't tuck the curtain in between the Y-axis table and the pan skirt, and I am also getting a leak through the pass through (which I have a fix for but am waiting on a couple of fitting to get my filter in place).
One of the first things I did was some tool holders brackets. I printed them out on a rapid prototyper and have them mounted on my peg board from wall control. I took it one step further and ended modifying one of these and mounted it to the side of my controller where I was able to located my 2 touch probes, less handling and moving around and therefore less chance of the renishaw probe tip getting damaged.
Finally the last modification was a better mount for the coolant lines, this is version 2.0 that I am testing. I drilled out and helicoiled the 4 holes located behind the spindle and bolted a rapid prototyped bracket that holds 4 adjustable nozzles. There is a pass through for the electrical wire for the spindle light and a flange that helps locate the light uniformly under the bracket. As soon as the rest of my fittings show up I'm running the supply line up through the motor area and in the umbilical on top of the machine where it will hook up to my filter (parts should be here early next week). Also I am currently working on version 3.0 and would like to split this bracket in half and put a hinge on it so that I can quickly flip it out of the way when I need to change tools, We will have to see how the hose management ends up working out as it may or may not work out.
