585,971 active members*
4,355 visitors online*
    Feb 2016
    8
    Trumpf TC260R Machine Fault37
    Hello All
    I have trumpf TC260R which was working ok. suddenly everything stopper and i have the followng msg
    Machine Fault 37
    Inhibit interr tool change m06
    Any Idea about the reason?
    Does any body have maintenance manual that i can check this fault in?
    Thanks & Reards
    Sep 2015
    21
    Re: Trumpf TC260R Machine Fault37
    Hey my quick reply for I work on lasers, I would look at your tool changer, try to move in manual think you should have that somewhere on your controller, Also check your tool in M06 ensure that everything looks good (take it out put it back in) etc..... also reboot would be good.
    Let me know more
    Feb 2016
    8
    Quote Originally Posted by Laserguyfiber View Post
    Let me know more
    Hello,
    Thanks for your reply
    I had bigger problem in the same machine when i press start pump, it starts for 1 sec and then turns off.
    machine shows me only emergency fault.
    any ideas?
    Thaks
  1. Which Laser Cutting Machine To Buy ??? MAZAK / AMADA / TRUMPF
    By vmmehta in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-04-2015, 01:16 PM
  2. problems on Trumpf laser cutting machine
    By arnoldino in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-03-2015, 04:17 PM
  3. Which laser cutting machine to go for? Mazak/ Amada/ Trumpf?
    By Henna in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-22-2013, 06:17 AM
  4. Trumpf Program is runnig, but the machine don't move.
    By Tribor in forum G-Code Programing
    Last Post: 05-16-2011, 01:31 PM
