585,883 active members*
5,196 visitors online*
    Jul 2012
    55
    Tangential knife - ultrasonic - oscillating
    Hello!
    I've got some request to cuts fabric, leather and linoleum and I'm in the process of making a tangential knife for this application.
    I've got a 130x260 cnc router with a vacuum bed so fixing the material should not be a problem.
    I started with a simple dragknife but was not satisfied. After reading the Eding CNC manual I had a tangential knife output to point the knife in the right direction with a steppermotor in under a hour and this is much cleaner way of cutting materials.
    I've got all the hardware (stepper, knifeholder, some bearings etc) but I was thinking to upgrade the system with a oscillating movement or maybe even a ultrasonic movement.
    https://www.youtube.com/watch?v=2T3bFvSPJS4
    In this video you see a ultrasonic knife.
    I don't have a ultrasonic cleaner but let's say I remove the piezo element and attached it to a blade and find the right frequency for cutting. Would it be that simple?
    I can't find real information on the internet but when I do find it I will post it in this topic.
    Jun 2014
    777
    Re: Tangential knife - ultrasonic - oscillating
    Interesting, but why not just use an ultrasonic oscillator, probably around the same price at about £7 each.
    Jul 2012
    55
    Hello Jon,
    Thanks for the replay, are ultrasonic oscillators not exactly the same as the units used in the cleaners? I would probably search for a kit with driver an oscillator.
    My biggest problem is (I think) the connection between the ultrasonic oscillator and the knife. It seems to be quite difficult to get the vibration right where it is needed. How would you connect the ultrasonic oscillator, between the rotating axis and the knife?
    Sadly there is not much information to find about this subject or i'm searching with the wrong keywords.
    Another option is this:
    https://www.youtube.com/watch?v=8pD1H2rKJ1w
    Just a jigsaw system, seems to work great. I've found information that the average is 3000 cycles per minute. You could do this with a small motor with a offset axis like a smal vibrating sander but I would like a pre build unit so that don't need to reinvent the wheel. Something like a solenoid system?
    Mar 2019
    5
    Sorry for digging out an old post, but I am interested in this too - any luck?
    Jun 2011
    692
    This Old Tony did a couple videos on ultrasonic cleaner/cutters recently.
    https://www.youtube.com/watch?v=pFeek0a8s7Q
    https://www.youtube.com/watch?v=FA46h7Db1BY
  1. Rotary milling or oscillating tangential knife for cutting Styrofoam?
    By marbles in forum Material Machining Solutions
    Last Post: 08-25-2015, 04:36 PM
  2. oscillating tangential knife
    By viscoelastic in forum DIY CNC Router Table Machines
    Last Post: 06-01-2013, 12:16 AM
  3. CNC conversion to tangential/oscillating knife
    By wb_dylan in forum DIY CNC Router Table Machines
    Last Post: 06-07-2012, 06:45 PM
  4. ultrasonic knife design
    By JNFSWE in forum Mechanical Calculations/Engineering Design
    Last Post: 01-31-2009, 01:10 AM
  5. to control tangential cutter w/oscillating
    By avengine in forum Machines running Mach Software
    Last Post: 04-20-2006, 04:23 PM
