Oh, I have the pulleys made already. Actually, they've been done for a couple of years. They are 10 groove micro belt pulleys. One is mounted to a splined hub that will drive the splined spindle and the other fits on the motor shaft. And the splined hub is made as well. Where I stalled out was on the tool holders. Drifting from R8 to TTS to CatR8 in my thinking and finally to BT30. That was a two year drift trying to make the case and do some minor testing for each type and I put everything else on hold until I got the spindle solved. And of course it has taken some time to gather the tool holders for the new spindle, but I'm back going on the belt drive conversion as soon as the chip enclosure is finished.
After testing the new motor, my confidence is pretty high on it being able to deliver if I don't get stupid in my programming. It did take me some experimenting in Mach to figure out the use of the pulleys to get my rpm ranges right, but now that I got that the motor seems to run in ranges that keeps the rpm in full torque mode. So the only doubt I have any more is on belt slippage. My use of the micro v belts this past year on the two other machines I have has shown them to be real dependable in that regard. Even in completely stalling the 1 1/2 hp motor on one of those machines, the belt never slipped a bit. So I'm getting some confidence in them to deliver on the mill. Trying to stall the new 3 hp motor on the test stand even at 300 rpm hasn't worked, so I'm getting some confidence there as well. But like everything else, it's all theory until I put it in use. Hope that's soon.
Bob
