586,000 active members*
4,898 visitors online*
Results 1 to 6 of 6
    Feb 2016
    Laser engraving anodized aluminum
    hello,
    I`ve been trying to engrave signs on black anodized aluminum (DuraBlack 0.005 coating) and it works well for small surfaces,
    but when engraving larger sheets I see soot like material deposition on the far side (from the starting position) of the sheet and browning of the metal underneath it, while other areas of the sheet are crisp white, a second pass doesn't clean the discoloration.
    I am using a 60w laser with 25-30% power and 70-100% speed , 600DPI.
    The sheet is not perfectly flat, it has a very small belly in the middle and is held on the perimeter.
    The focus is set right and there doesn't seem to be a correlation between the unevenness and the discoloration.
    I`ll gladly take any advice you can throw at me on how to resolve this.
    Thanks a bunch.
    May 2015
    53
    Re: Laser engraving anodized aluminum
    Quote Originally Posted by Touchme View Post
    hello,
    Thanks a bunch.
    Hi ... Attach a picture of what happened to your problem and will be easier to help you ... Preferably with a sharpness in ...
    Feb 2016
    Attachment 309046
    here is a pictures of what happened,you can see browning of the letters on the top of the pic compared to the letters on the middle/bottom.
    May 2015
    53
    Attachment 309046
    Have you tried to put the piece to record elsewhere in the table to test if the problem persists? Had to write reversing the art starting recording side who finished first?
    Enviado de meu B1-730 usando Tapatalk
    Feb 2016
    It looks like maybe some of the ablated material has re-condensed on the aluminum.
    Nov 2012
    492
    what psi are you running your air assist at ? Try increasing psi some see if that helps.
    Quote Originally Posted by poulintr View Post
  1. Engraving turret knobs (anodized/coated aluminum)
    By Huckmeat in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-03-2011, 01:47 PM
  2. Engraving Anodized Aluminum: chipping?
    By Frogblender in forum Engraving Machines
    Last Post: 03-17-2010, 06:46 PM
  3. laser engraving on anodized aluminum
    By ezflowrider in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-02-2009, 01:25 AM
  4. Engraving anodized aluminum - color fill?
    By Neil_J in forum Hobby Discussion
    Last Post: 09-17-2008, 03:11 AM
  5. Engraving in anodized aluminum
    By fish09 in forum Engraving Machines
    Last Post: 08-24-2007, 10:02 PM
