584,812 active members*
5,502 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Colombo RS73 cooling fan question.
    Hiya,
    I got this Colombo RS73 spindle in 2008 on a small K2 machine. Situation changed and it got put into climate controlled storage until recently. I have everything set up and I can turn the spindle on and off from the machine and I can adjust the rpm of the spindle. What is bothering me is the cooling fan doesn't come on. I don't know if it's supposed to come on with the spindle, or if there is a temperature sensor? I have only run it for a couple minutes until I know for sure. tia
    Re: Colombo RS73 cooling fan question.
    In case anyone else has a similar question, I heard back from Colombo. The fan is powered separately from the spindle. It is a 220vac fan. I need to dig in and see how K2 wired it.
    Feb 2018
    This is an old thread, but still, how did you connect the spindle and fan? This image is from my rs73 and I think three brown lines should connect to the vfd, and two black lines straight to 230V/50Hz. Am I right?
  1. 10hp COLOMBO - FAN COOLING CONVERSION
    By jxdxwx in forum Spindles / VFD
    Last Post: 06-17-2015, 03:28 AM
  2. Quick Question On Cooling Stepper Motors
    By willheg in forum Stepper Motors / Drives
    Last Post: 04-21-2012, 07:50 AM
  3. PDS colombo and Giordano Colombo
    By 15mgtar in forum Want To Buy...Need help!
    Last Post: 07-10-2011, 12:47 AM
  4. Question about cooling
    By matty440 in forum European Club House
    Last Post: 06-17-2008, 09:52 AM
  5. Cooling question
    By cncadmin in forum Computers / Desktops / Networking
    Last Post: 11-18-2003, 02:49 PM
