585,762 active members*
4,033 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Building a new large CNC hotwire
    Feb 2016
    Hey Guys, i am looking to build a very large CNC foam cutter for my business, the software sounds pretty straight forward but i need the guides or railings with motors to be extremely strong, the machine cut area is 100 X 55 x 55 inchs.
    What do yo guys recommend for something like that ?
    Jan 2008
    932
    Re: Building a new large CNC hotwire
    Well the wire never touches the foam when cutting, so there is NO pressure on the machine from that, the only thing you need is motors strong enough to move the weight of the machine.
    Wood neophyte.
    Apr 2007
    1955
    It looks like the main challenge will be obtaining smooth motion and not having wobble in the large components.
    While that might seem easy, it often is not quite that simple over large distances. I would look at what is done over in the wood cnc home built section in terms of frames. Most of those are actually not stiff enough for the intended task, so they are about right for your task.
    Apr 2007
    238
    Mine has a cut capacity of 49.25"x82.5"x120.5" and can cut 2 48x36x120 blocks at one time, has 2 axis mode, 4 axis mode and 5th axis turntable. I machined the 10'+ x axis guides from 1.5" cold-rolled steel. The Y axis rails are aluminum and came from a place called "Flatboys" or maybe "Phatboys"? You won't need the strength for these like you would for something like a router because the loads, speeds, acceleration and G forces are far less.
    Following. Starting to research building (or maybe buying) a foam cutter that could handle a 96"x48"x48" block of foam (the wire would need to be 98" long). Seems simple enough, X,Y on one side, Z,A on the other, hotwire stretched between.
    Like building two 50"x50" machines facing each other. Looking at other threads it appears that most of the heaving lifting of programming has already been done.
  1. Building a machine specifically for large hardwood 3d milling.. looking 4 suggestions
    By rhadiem in forum Uncategorised WoodWorking Machines
    Last Post: 03-11-2017, 12:25 AM
  2. Going to be building a large plasma table.
    By Galane in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-05-2013, 10:56 PM
  3. new cnc hotwire cutter large cutting 0 floor space.
    By alans in forum Signmaking Topics
    Last Post: 05-17-2012, 09:17 PM
  4. Building an enclosure for a large benchtop mill. (pics)
    By touser in forum Benchtop Machines
    Last Post: 12-31-2009, 08:31 PM
  5. Looking for CNC hotwire
    By Vin_uk in forum CNC Wire Foam Cutter Machines
    Last Post: 12-09-2009, 11:28 PM
