585,567 active members*
3,424 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > Large machine requires sturdy slot or rail
Results 1 to 6 of 6
    Feb 2016
    Hi guys, i am looking to build a 8 x 4 x 4 foot machine (hot wire cutter) i need rails or T slots and motors. I have seen allot of people use extruded aluminum to build these machines, any good sources for materiel ?
    Feb 2016
    Re: Large machine requires sturdy slot or rail
    Any thoughts
    May 2008
    4068
    Quote Originally Posted by Titan262 View Post
    Any thoughts
    There is this profiles for easy set up of machine
    Attachment 309550 Click image for larger version.
    XZero cnc
    Nov 2007
    25
    Titan, this company builds these kinds of frames. If you would like some assistance in either building or getting the material, check out the site and send them an email or call.
    Framing Tech
    Jun 2014
    777
    Quote Originally Posted by gio666 View Post
    They are too weak for 8x4. You need heavy grade if you don't want it to take all day to cut one job. Heavy grade is the stuff with twice as thick walls. I used 9090. For an example search Kjn aluminium profile and find 9090 heavy.
    Sorry just read wire cutter, ignore me.
  1. New machine: small, sturdy, high performance. Input needed!
    By aarongough in forum DIY CNC Router Table Machines
    Last Post: 05-31-2015, 02:53 PM
  2. t slot with built in v rail
    By d2james88 in forum Want To Buy...Need help!
    Last Post: 01-06-2014, 01:00 AM
  3. "tool slot number too large" code
    By dave6 in forum Mach Mill
    Last Post: 10-10-2006, 11:57 PM
