585,991 active members*
4,725 visitors online*
Page 8 of 8 678
Results 141 to 142 of 142
  1. #141
    Jun 2011
    14
    I've made some small additions to the original Joes 2006 while I tried to keep the original design in the new parts.
    At first I installed a rail at the backside of the gantry, which is simply attached to the PE bearing mounts. The rail is used for the limit switches and the cable carrier.
    A similar attachment is mounted to the right side close to the Y-axis bearings. Also here the cable carrier is connected, as well as the limit switches and some part to fix the hose from the vacuum.
    To clean the the parts while cutting the vacuum is connected close to the router. The brush is fixed by some strong magnets to remove it quickly when necessary.
    Greetings
    Cornelius
  2. #142
    Jul 2007
    61
    Does anyone have the dust shoe file? I can't seem to find it.
Page 8 of 8 678
