585,982 active members*
4,648 visitors online*
    Feb 2016
    100 wt to 80 wt tube replacement
    my 100 wt tube got cracked i would like to know that if i replace it with 80 wt so do i need to change the
    power supply as well or on 100 wts power supply can be used for 80 watts also.
    please need the assistance.
    Apr 2004
    475
    Re: 100 wt to 80 wt tube replacement
    Quote Originally Posted by inayathinfotech View Post
    No, but you do need an (milli)amp meter to determine the new max power level to use in the software settings....it's not linear either, my 80w tube with an 150w power supply had a new max of 72% power, for example. If you don't have a meter, you'd want to be conservative.
    Greg
    Sent from my ASUS_Z00TD using Tapatalk
  1. zurong photoelectronic replacement Co2 tube rip off
    By klevabuga in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2021, 03:58 AM
  2. Replacement Co2 Laser Tube?
    By Sean3073 in forum Polls
    Last Post: 09-21-2015, 03:46 PM
  3. Please Help! Chinese K40 tube replacement
    By trimpy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-07-2015, 07:35 PM
  4. TNC screen / tube replacement
    By FLjoyride in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2011, 02:47 PM
  5. replacement laser tube
    By Gary123xyz in forum Engraving Machines
    Last Post: 07-30-2011, 12:18 PM
