585,733 active members*
4,786 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Ridgid tapping No.10-24 thread
Results 1 to 6 of 6
    Oct 2004
    Hello,
    Need expert advice on ridgid tapping a No.10-24 thread on stainless steel 316L my drill depth will be .5 deep my full thread depth needs to be .4 Im holding the tap on a ER16 collet holder but should be getting my ER16 collet holder with the square bottom tomorrow so the tap doesnt spin. We pecked it 4 times at equal increments our rpm was 180 and broke 2 taps in 3 holes...? Tap is a flat bottom tap for blind holes. Machine im using is a Mazak 510c-2 with the nexus matrix control which based on my serial number the machine is equiped with ridgid tapping capabilities. Anyone whos been able to tap successfully tap with this thread please chime in. Im using OSG HSS coated taps at 25 bucks a pop and 1000 holes to tap I need all the advice I can get. Thank you everyone in advance.
    George Montes
    Jan 2016
    13
    Re: Ridgid tapping No.10-24 thread
    What are you using for tapping fluid? Try Moly D. Drill the hole oversize. Do not work harden the material when drilling the hole. I do not have luck with osg taps. Try emuge.
    May 2015
    70
    Quote Originally Posted by Needshave View Post
    Moly D is definitely the way to go. Don't be afraid to try a roll tap either. We had great success roll tapping Inconel castings.
    Mar 2012
    109
    I've also had a lot of trouble tapping stainless. We ended up switching to emuge taps and reducing the thread % cut.
    Feb 2011
    353
    i would try roll form tapping but the tap would have to be a 10-24 bottom tap(1-2 thread lead) with a cobalt base material with ticn coating ---drill would be 11/64 diameter to cut at about 65% full thread to make it easier on the tap
    the other thing that you could try is a high spiral flute design that would bring the chips out of the hole again a cobalt substrate and the ticn coating using a #23 drill .154 dia. again about 65% thread
    Jan 2013
    126
    I would definitely try a good quality spiral tap such as a guhring g3
  1. Ridgid tapping on Fanuc
    By peaceandcalm in forum Fanuc
    Last Post: 10-25-2020, 12:11 PM
  2. DS30SSY Ridgid tapping cycle
    By cgmr53 in forum Haas Lathes
    Last Post: 06-27-2012, 11:53 PM
  3. Ridgid Tapping 1/4-20
    By southernexplore in forum Haas Mills
    Last Post: 10-16-2009, 08:45 AM
  4. Ridgid Tapping on Haas
    By Shotout in forum Haas Mills
    Last Post: 08-02-2006, 03:40 AM
  5. ridgid tapping with servos
    By miljnor in forum Servo Motors / Drives
    Last Post: 09-21-2005, 07:35 PM
