Number |
Description |
Parameter |
1 |
X,Y,Z Working Area |
1300x2500x400mm*180degree |
2 |
Table Size |
1450×2940mm |
3 |
X,Y,Z Traveling Positioning Accuracy |
±0.03/300mm |
4 |
X,Y,Z Repositioning Accuracy |
±0.03mm |
5 |
Table Surface |
Vacuum and T-slot Combined (Option: T-slot table) |
6 |
Frame |
Welded structure |
7 |
X, Y Structure |
Rack and Pinion Drive, Hiwin Rail Linear Bearings |
8 |
Z Structure |
Hiwin Rail Linear Bearings and Ball Screw |
9 |
Max. Power Consumption |
(Without Spindle) 5.5kw |
10 |
Max. Rapid Travel Rate |
45000mm/min |
11 |
Max. Working Speed |
30000mm/min |
12 |
Spindle Power |
3.0/4.5/6/7KW |
13 |
Spindle Speed |
0-18000RPM |
14 |
Drive Motors |
Yaskawa servo |
15 |
Working Voltage |
AC 380V/50/60Hz,3PH |
16 |
Command Language |
G Code |
17 |
Operating System |
Syntec Control System |
18 |
Computer Interface |
Enthernet, CF Card |
19 |
Flash Memory |
512M |
20 |
Collet |
ER32 |
21 |
X,Y Resolution |
<0.03mm |
22 |
Software Compatibility |
Type3/UcancameV9 software (Option: Artcam software) |
23 |
Running Environment Temperature |
0 - 45 Centigrade |
24 |
Relative Humidity |
30% - 75% High Efficiency and Low Cost Smart Wood Router with 4 Axis CNC |
