585,996 active members*
4,856 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Mastercam X8 and Tormach Path Pilot
    Sep 2015
    6
    I just got a pcnc 1100 with path pilot and I'm using Mastercam X8. I downloaded the Post processor from Tormach website and it does not seem to be compatible as it is a X7 version. The site claims this is the latest version. When installed tormach is not in the list for mills.
    Any help would be appreciated
    Jun 2007
    110
    Re: Mastercam X8 and Tormach Path Pilot
    In Mastercam you can use the migration wizard and it will convert existing files - including posts, tools, etc..
    You might also check out this existing thread... http://www.cnczone.com/forums/tormac...rcam-post.html
    Kevin
    Sep 2010
    22
    Path Pilot is LinuxCNC with some lipstick on it. I don't use MasterCam, but for HSMXpress, I pick the EMC post processor and it works for me. Maybe Master Cam has a LinuxCNC or EMC post processor and use that.
    Oh, EMC was the previous name of LinuxCNC until the large software company EMC forced a name change...
    Hope that helps, good luck. Mark
    http://www.ijohnsen.com/blog
    May 2008
    77
    for the most part you can use the standard 3 axis fanuc post and it'll work. I honestly didn't even know tormach released a mastercam post, so I edited mpmaster to make my own tormach post.
    Nov 2005
    201
    Yeah i use the generic haas post
  1. Got my Path Pilot
    By BIG IGG in forum Tormach PathPilot™
    Last Post: 02-10-2016, 03:06 PM
  2. What comes with Tormach's path pilot?
    By 1abrat in forum Tormach PathPilot™
    Last Post: 11-26-2015, 08:23 PM
  3. Tormach 1100 seriers 3 running Path Pilot X Axis jammed up.
    By kenny calman in forum Tormach Personal CNC Mill
    Last Post: 10-17-2015, 07:49 PM
  4. CNC Scanner and Path Pilot
    By RA-Bowtie in forum Tormach PathPilot™
    Last Post: 10-12-2015, 05:31 PM
