I posted this on the Daewoo/Doosan forum without anyone with a reply I do not use any type of Cam software if anyone could generate a simple code of radius approach in and square mill profile and radius escape out using x/c axis moves using a 1/4" dia. end mil that would be a big help to me
Hi all I have a question in regards to making an internal square with a radius approach in and approach out I have been doing the square with no problems using the X and C axis, however I would like to have the approach radius in and escape radius out added to this sample listed below I added all the main variables that pertain to the square width and depth plus the drilling cycle (T1113) before the square milling operation just to give everyone insight of the machining process I use before the actual internal square milling cycle(T0527) if you all have good suggestions in regards to approach radius in and escape radius out I would appreciate it.
#102=.781(CORNER RELIEF HOLE PATTERN FOR INTERNAL SQUARE)
#103=.756(ACTUAL MEASUREMENT .756)
(INTERNAL SQUARE SIZE SUBSPIN)
#104=.625(INTERNAL SQUARE DEPTH SUBSPIN)
M1
T1113(.687 CARBIDE INSERT DRILL SUB.
PRIOR TO MILLING INTERNAL SQUARE)
G0G28B0.
M110
G80M8
G97M4S1800P13
G0G99X0.Z-.1
G1Z.71R0.F.007
G0Z-.1
X.1
G1Z0.
X.0685Z.05
Z.69
X0.
G0G80Z-.5M9
G28U0.
M5P13
M5P11
M1(MILL SQUARE SUBSPIN SIDE)
G0G28U0.
G28B0.
M190
M135
G0G28H0.
T0527(1/4 CARBIDE MILL AXIL TOOL SUBSPIN SIDE)
(SET GEO.R OFFSET TO RAD.OF ENDMILL)
M190
M135
G97M3S2900P12
G13.1
M110
Z-.1M8
X0.(APPROCH TO PART DIA.OF PART+.05+ DIA.OF CUTTER)
G12.1
G42
G1G98C[#103/2]F5.(START MILLED FLATS)
G1G42X#103F5.
Z#104F3.(Z DEPTH OF SQUARE)
C-[#103/2]F5.(END OF 1ST.FLAT)
X-[#103](END OF 2ND.FLAT WHOLE WIDTH)
C[#103/2](END OF 3RD.FLAT)
X[#103-.25](END OF 4TH.FLAT)
Z-.1F120.(MOVE AWAY FROM PART FACE BEFORE G40 CUTTER COMP.CANCELL)
G40X0.
G13.1
G0Z-.1
C45.
X#102(CORNER RELIEF BOLT HOLE PATTERN)
M89
G1Z#104F5.
G0Z-.1
M90
C135.
M89
G1Z#104
G0Z-.1
M90
C225.
M89
G1Z#104
G0Z-.1
M90
C315.
M89
G1Z#104
G0Z-.1
M90
G28U0.
M5P12
M5P11
M134
M30
