This forum is really great and I am finding answers all over, so thank you. :drowning:
I have seen this problem a few times and have not found an answer online.
My machine is cutting OK, but I can't get the Proma THC to adjust the Z axis while cutting.
I ran the test cycle for the proma unit, and seems like I have my wiring correct.
- The physical torch Z moves up and down
- Z DRO rises and falls (mach3)
- The LED lights in the diagnostics page blink on and off. (mach3) torch up, torch dn, torch ok
My settings are:
THC voltage 130V (50:1 divider)
hypertherm85, 65 amps
air pressure 105psi, lots of drying and filtering
mach3
sheetcam
autocad
I go through all my menus in Mach in the videos, so if you could please watch and look for a mistake, I would be very grateful.
It could be something easy and obvious, I am not an expert and still learning the functions of mach3 and the CNC world.
Thank you.
Videos
Showing THC Test Cycle:
https://youtu.be/ZMykjwZaSo8
Showing Failed Cut & settings (start to finish):
https://youtu.be/rR-vu3DjqqQ
