I am using a coupleof AMC be25A20 brushless servo amps.
They have a nice feature... apply the quadrature pulse trian and it will generate tacho signal internally to close the velocity loop.
MAJOR PROBLEM the tacho gain is set to 22KHz for 1 Volt output.
No way to change that on board. Worse still the goos people at AMC have scrubbed off IC labelsso hard to determine whihc chip(s) is used in the tacho circuit.
The machine generates a 7500KHz signal under conditions of normal operating speed.
Anybody out there with the knowledge of how to reduce the frequency for a decent signal output? Say 2 KHz/1volt!
