Parameter |
Function Description |
Data Description |
Default |
Current Setting |
Note |
Pn 01 |
The default display |
1-60 |
1 |
1 |
Pn 02 |
Initial frequency |
0.01-400.00 |
50 |
50 |
Pn 03
Frequency source selection
1-7
Pn 04
Run command source selection
1-2
Pn 05 |
Forward / reverse run prohibited |
1-3 |
3 |
3 |
Pn 06 |
Stop mode |
1-2 |
2 |
2 |
Pn 07 |
External power signal restart |
1-2 |
1 |
1 |
Pn 08
Acceleration time
000.01S-650.00S
10S
will not run with default of 10.
Pn 09
Deceleration time
000.01S-650.00S
10S
8
Pn 10 |
The maximum operating frequency |
000.10Hz-400.00Hz |
400 Hz |
400 |
Pn 11 |
The lowest operating frequency |
000.10Hz-400.00Hz |
1.5Hz |
1.5 |
Pn 12
Reference frequency
010.00Hz-400.00Hz
40 Hz
60
Pn 13 |
Torque compensation |
0.0-4.0 |
0.0 |
0 |
Pn 14 |
End torque compensation frequency |
0.01Hz-400.00.00Hz |
10Hz |
10 |
Pn 15 |
DC brake voltage |
1V-100V |
30V |
30 |
Pn 16 |
Starting DC braking time |
000.00S-650.00S |
0S |
0 |
Pn 17 |
Stop DC braking voltage |
1V-100V |
30V |
30 |
Pn 18 |
Stop DC braking time |
000.00S-650.00S |
0S |
0 |
Pn 19 |
Multi-speed frequency source selection |
0 1-5 |
1 |
1 |
Pn 20 |
Multi-speed frequency 1 |
000.10 Hz-400.00Hz |
10 |
10 |
Pn 21 |
Multi-speed frequency 2 |
20 |
20 |
Pn 22 |
Multi-speed frequency 3 |
30 |
30 |
Pn 23 |
Multi-speed frequency 4 |
40 |
40 |
Pn 24 |
Multi-speed frequency 5 |
50 |
50 |
Pn 25 |
Multi-speed frequency 6 |
60 |
60 |
Pn 26 |
Multi-speed frequency 7 |
70 |
70 |
Pn 27 |
Jog frequency |
10Hz |
10 |
Pn 28 |
Relay output function selection |
1-6 |
3 |
3 |
Pn 29 |
Second acceleration time |
000.01S-650.00S |
2S |
2 |
Pn 30 |
Deceleration Time |
000.01S-650.00S |
2S |
2 |
Pn 31 |
Second deceleration end frequency |
000.01Hz-400.00Hz |
1Hz |
1 |
Pn 32 |
Parameter Management |
1-3 |
1 |
1 |
Set to 3 then back to 1 Then set required parameters |
Pn 33 |
Software version Custom manufacturers |
33022 |
Pn 34 |
Instantaneous power failure automatic recovery |
0-99Hz |
0 |
0 |
Pn 35 |
Date of manufacture |
15066 |
