585,712 active members*
4,131 visitors online*
Results 1 to 1 of 1
    Aug 2014
    45
    Spring loaded pen plotter tool
    I recently made a spring loaded pen plotter tool for my CNC Router I thought I would share. Before making this device I tried using a non-spring loaded plotter pen which was pretty expensive and it tended to skip or tear the paper.
    The spring loaded device I made seems to work very well. The tool uses a Lamy M-22 ballpoint pen ink cartridge, a small spring, and a 5/16” set screw. I made the body of the tool out of 1/2” acrylic rod but it could also be made out of aluminum or just about any material. I chose the Lamy M-22 cartridge simply because it was the shortest. It’s a bit expensive, about $7 on Amazon and comes in different ball sizes and colors. I made the body on my CNC Mill but you could also make in on a good drill press if you are careful and accurate.
    I use CamBam for most of my work and to plot something rather than cut it, I select all the lines, circles, arcs, etc. on the drawing and then define a machining process that does a profile cut using a tool with a specified 0" diameter I also specify the depth of cut at 0 and a clearance plane of .25". Before plotting, I position the spring loaded pen at the center of the paper and set the Z Axis to about .04" below the surface of the paper to load the spring.
    Attached Thumbnails Attached Thumbnails DSCF1128.jpg   DSCF1125.jpg   PlotPen.jpg   Panel Plot.jpg
  1. Spring Loaded Engraving Tool
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 12-06-2018, 05:08 PM
  2. New spring loaded engraving tool
    By BTP in forum News Announcements
    Last Post: 06-13-2015, 11:55 PM
  3. Spring loaded engraving tool?
    By phatjap in forum Want To Buy...Need help!
    Last Post: 04-20-2010, 06:12 PM
  4. Anyone use a spring-loaded engraving tool?
    By laka in forum MetalWork Discussion
    Last Post: 01-08-2009, 05:09 AM
  5. Spring Loaded Engraving Tool
    By djh82uk in forum MetalWork Discussion
    Last Post: 01-11-2008, 05:35 AM
