585,996 active members*
4,544 visitors online*
Results 1 to 12 of 12
    Aug 2003
    329
    Re: Hoss G0704
    Hoss,
    If you had to choose a new motor for the G0704 today what would you put on it?
    Bill
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
    Mar 2016
    19
    Re: Hoss G0704
    bump, interested as well
    Mar 2012
    109
    Re: Hoss G0704
    This seems like a moot question without constraints. Where do you need the power/torque band to lie? What's electrical options do you have available? What's your price range? Ultimately your own needs will dictate what motor you choose to run. If the sky is the limit, snag a VFD and a bigass motor. Keeping it cheap, get a treadmill motor or whatever you can find around. Hell, go Servo drive.
    Mar 2016
    19
    Re: Hoss G0704
    i would prefer something that would allow for a power draw bar option (later down the road)
    Mar 2012
    109
    Re: Hoss G0704
    So, anything except direct drive. And even so, that's doable with some exceptional finangling
    Mar 2016
    19
    Re: Hoss G0704
    was thinking of ordering one of those 1100W bldc motors, looks small enough to maybe work
    Re: Hoss G0704
    Quote Originally Posted by bgriggs View Post
    Hoss,
    Bill
    There are a number of options here, if money wasn't a deterrent I'd get a big servo.
    Projects
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Aug 2003
    329
    Re: Hoss G0704
    I already purchased a motor. Since I had a VFD laying around I grabbed a Leeson 3 phase motor. D80 frame metric motor, 1.5 HP, 3475 RPM.
    https://www.zoro.com/leeson-metric-m...30/i/G1171265/.
    Since I am using a head spacer I think the motor will fit without much problems.
    Aug 2003
    329
    Re: Hoss G0704
    I posted the wrong motor. This is the correct one. https://www.zoro.com/leeson-metric-m...2/?q=192067.30
    Feb 2014
    227
    Re: Hoss G0704
    Hi I was wondering how your motor setup is working. Is the Leeson motor giving you the RPM and power for milling that you were looking for?
    Jeff
    Aug 2003
    329
    Re: Hoss G0704
    I picked up the Leeson 3 phase motor and got it hooked up to a HuanYang VFD. The VFD was not hard to hook up and does a nice job of controlling the motor. However, I have not yet finished hooking it up to the mill.
    I got a belt drive from Benchtop Precision made for this motor. There are some really nice features with this drive, like the ability to keep the quill working. I got one of the first mounting plates so there are a few things that need attention but I am looking forward to having this setup on my machine.
    Bill
    Attachment 321820 Attachment 321818
    Aug 2003
    329
    Re: Hoss G0704
    I have been working on fitting the Leeson motor to the Belt drive.
    The motor mount is being redesigned specifically for this motor. Leeson changed the motor without updating the CAD files to match. There are a few Clearance issues that Scott (Benchtop Precision ) is aware of and is fixing. We are emailing and getting things worked out so thing fit perfectly. As it sits now the belt drive can be made to fit but Scott want it to be plug and play. I will post some pictures later. But the main issues are that the belt tension slot is too close to the motor endbell, so removing the bolts is difficult. Nothing insurmountable.
    Bill
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-16-2024, 11:51 AM
  2. Hoss's G0704
    Last Post: 03-25-2016, 12:48 AM
  3. Hoss G0704 or similar
    By m1n1m in forum Want To Buy...Need help!
    Last Post: 10-30-2015, 12:49 PM
  4. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  5. RFQ A few parts from Hoss G0704 Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 10-21-2011, 09:13 PM
