585,768 active members*
4,197 visitors online*
    Mar 2016
    Laser Cut 5.3 Not cutting to correct size!
    Just noticed on our 60W Signify laser that uses Lasercut 5.3 that it is cutting incorrectly. It cuts out shape perfectly but the dimensions of the finished product are way out!
    A 50mm x 50mm square comes out a 44 x 44. On screen when downloaded to the Lasercut screen it measures 50 x 50 but it I actually cutting the shape about 10% smaller. Am I missing something simple???
    Sep 2008
    68
    Re: Laser Cut 5.3 Not cutting to correct size!
    You need to change the pulse per minute for the X and Y steppers.
    Take the current pulse value for x & y and divide it by 44- this will give you a figure for the current pulses per millimeter for your machine X & Y.
    Simply take the pulse per millimeter and multiply by 50
    You will now have an accurate value for the number of pulses your machine- enter this under the options menu and your machine will now be corrected to match the actual stepper motors not a theoretical value.
    In your case X & Y ae out by the same amount which makes things easier- you can adjust X and Y individually if needed.
    Aug 2016
    83
    44/50*the current pulse, save download cfg, download all. finish
    Chencan cnc router from 1998.
    skype marylee0411
    Jan 2014
    27
    I'm having the same problem, I am cutting a 19x19mm square and actual cut size is 18.6x18.6mm, can someone please tell me exactly what needs to be done ?
    Where can I find the current pulse value for X&Y ? is the value in the screen ? If so, what do I need to do with it precisely ?
    BTW my lasercut version is 6.1
    Oct 2016
    hi
    first to fix this prb folow me step by step
    1- go and draw 50*50 SQUARE (before changing any parameter )
    2- measure the SQUARE WITH PRECISION .
    FOR EXEMPLE THE measured SQUARE IS 40*30
    start by fixing x axis
    to do this u have 2 parameters
    per length and pulse counts
    nice nice
    /current settings
    per length = 15.000
    pulse counts = 1000
    so the controller give 1000 pulse to move 15 (for our case we give 50mm and it moved 40mm
    15 need 1000
    50 need (50*1000)/15 = 3333.333 pulse
    but in fact 3333.333 move the head for only 40
    now just go and update ur settings
    40 need 3333.333
    15.00 need 15*3333.333/40 = 1250
    per length = 15.000
    pulse counts = 1250
    or just
    per length = 40
    pulse length = 3333.33
    the same thing for y axis
    i hope this will be helpful for u and other members thank u :banana:
  1. Chinese Laser not cutting to correct scale
    By IvanC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-10-2014, 03:11 PM
  2. Cnc not cutting correct size
    By hoops1888 in forum Mach Software (ArtSoft software)
    Last Post: 07-04-2013, 10:41 PM
  3. middle size, up and down table, laser cutting machine
    By vivinar in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-18-2012, 09:06 AM
  4. What size laser for cutting sheet metal?
    By killersoundz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-17-2011, 09:29 AM
  5. Large size laser cutting machine DC-1324
    By mandyfang2006 in forum News Announcements
    Last Post: 01-13-2009, 10:14 AM
