585,906 active members*
3,842 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > letter engraving (V-carved) newbee help
Results 1 to 10 of 10
    Oct 2006
    259
    I could exposed and have a debate on how I’ve plotted the toolpath strategy, but I think this time....it may be easier to ask what would be the best tool option & toolpath strategy for this type of “simple” work !!...as my end result is not satisfying at all...mostly with the small phone number part. !?!
    Here's some info :
    wood plaque size = 3 x 2.25
    Font = Agency FB
    #29 height = 1inch
    phone number font height = 0.25
    Any guidance & recommendations would help, as I’m commissioned to do over a hundred of those !!...
    Jun 2008
    562
    Re: letter engraving (V-carved) newbee help
    Here is the bit I use : Signmaking & Lettering Router Bits by Timberline
    I assume the small numbers are not showing up well due to limited depth. You could try a "bold" number(see jpeg), or a 45 or 30 degree cutter. How about increasing the size of the numbers
    A standard V carve toolpath should work.
    Good Luck
    Mike
    Oct 2006
    259
    Thanks for your time MIKE....
    Actually....not quite an issue this depth thing !
    It's more a strategy thing, like....a combination from the font actually making it not as easy as some others and....the right tool for the font size, meaning, having a tool where it would make a clean cut.
    I'd say ( thought I had even before posting this issue first) it'a a kind of situation I'm having where it would be instructive to have a few "verry experianced" Aspire users having an open discution about the possible strategy to use !
    But...this will not happen in a virtual forum.....at least in a simple communicative fashion ;0))
    here's a pic of what I'm having as what I call...not satisfying...issue !
    done on a test cherry piece
    What you see here is : On the left it was done with a 22.5° bit ( or 45° total) ( see here : CNC V Groove, Miter Fold & Signmaking Router Bits with Solid Carbide Insert Knives - Toolstoday.com - Industrial Quality CNC Bits
    and on the left, using a smaller one, a 15° (or 30 total) like this one ( see RCK360 form the engraving V-bit selection : In-Grooveâ„¢ CNC Insert Engraving System -Toolstoday.com- Industrial Quality Engraving & Signmaking Insert Router Bits
    As you can see....the result is fare from nice....I tend to say, mainly cauz of the font style combined with it's inpaired small size ( 0.250 hight)....witch BTW....is in BOLD format @_# !!
    It's hard to tell from the pictures what the issue is. Are you looking for cleaner cuts?
    What type of wood is this? Looks like a Luan or similar? Is it possible to seal the wood first? Sealing or finishing first will give much cleaner cuts.
    I've never used an In_groove bit, but I don't think that it is the best choice.
    Are you doing a V Carve with a flat bottom? For small letters, a 1/8" downcut might be a better choice.
    Oct 2006
    259
    Hi Gerry, thanks for chipping in !!....always enjoy your comments and knowledge @_# !!
    As said, this one is done on a cherry test piece !
    It's always "possible" to seal 1st....if it's a solution.....Solution I've never tried before (for engraving), so may be worth a shot ?
    As for In-Groove, it's new to me, in the past, only a few times, I've been using other insert type V-cutter holder such as the above link for the RC-1045 !
    I tend to think thus far, the IN-Groove is not the issue...but more a code "18" !!
    Agree as for a downcut mill may give a better output, but in this case, letters width are smaller, I would need say like a 1/16, witch is possible, but for over a 100pc....just to expensive and...time consuming in tool change I'd say ?!!
    One of my question is: can there be a difference in ASPIRE toolpath output file if we chose the same tool ( say this RC-1045), but on one test, say I’ve custom plotted that tool as a V-carve tool and on another option I’ve plot the same tool as a engraving tool.
    Would the end result ( output) be (should be) the same, if the parameters ( font selected and cutting strategy same) are equal ?
    Just hopping to find a solution to minimize the fuzz and yield a better cut quality !
    BTW...
    As pointed, this test was on cherry, but the commission order is on various type ( exotic as domestic too )
    PS...i'v spent many hrs trying to figure out a better output, and it's all worth it as it's a nice learning cure....not to say a must !!....but maybe, just maybe....i'm battling this for nothing and should sub it out to an laser etching / engraving since the letters are maybe just to small to be engraved by a woodCNC ??....questioning out loud ?!?....in my view, we (wood CNC users) should be able to do this ?!??
    Jun 2008
    562
    Looks like you are doing a Vcarve with a flat bottom?? Using a Vbit with a 60 or 90 degree (with no flat pocket toolpath ) cut to full depth will give you a cleaner cut. That assumes a flat at the bottom is not a requirement.
    What were your tool path parameters?
    Added a picture of a Cribbage board done in pine with flat bottom and standard vcarve parameters with the cutter I suggested and had no issues like you are seeing.
    Did you have a final pass step over in the tool for final cleanup?
    Mike
    Jun 2008
    562
    The more I look at your pics it almost looks like you were doing a regular "pocketing" and the tool was leaving scallops at the stepover point, Yes , No??
    Mike
    Oct 2006
    259
    Mike...
    In the V-carve test setup, no...no flat bottom, but yes when I test in "engrave" tool set up !
    As for flat bottom, no need from the client, not required.
    Tried it with a 90° total angle, but it seem to be "to wide" for the small letters.....but perfect for the bigger # 29 !!
    As for parameters, a screen shot tells more.....
    Oct 2006
    259
    Quote Originally Posted by Mike 1948 View Post
    Mike
    NOp...
    Oct 2006
    259
    I though you may enjoy my finding with quite a satisfying final output !
    I owe this forum this at least !!
    Finally, I've set it up with a 60° V-carve tool.
    The setting are : Attachment 310676
    and the output....which I'm pleased with ... Attachment 310678
    Thanks Mike, Gerry
  1. Need Help with engraving letter stamp
    By WOTDesigns in forum Mastercam
    Last Post: 09-15-2015, 11:41 PM
  2. Engraving letter in aluminium
    By pretorian77777 in forum ArtCam Pro
    Last Post: 02-26-2014, 02:54 PM
  3. engraving letter a problem
    By MIDDEN300 in forum BobCad-Cam
    Last Post: 08-11-2012, 05:25 PM
  4. Letter-engraving tool
    By Vard in forum Wood Lathes / Mills
    Last Post: 03-29-2012, 11:53 PM
  5. Replies: 3
    Last Post: 05-18-2009, 12:00 PM
