585,992 active members*
5,600 visitors online*
    Dec 2011
    Copper Lathe Job
    I'm working on a Ø6in. x 9in. Length Copper C110 job and I need to know the maximum safe RPM. I have a Hardinge H51 Lathe with a 10" 3 jaw chuck and I'm using hard serrated jaws. Thanks!
    Mar 2012
    109
    Re: Copper Lathe Job
    Ultimately you need to know the clamping force on your chuck, then the cutting forces that you are going to be applying to the workpiece. C110 can range in hardness from B50-B95 or so so your surface speed will be affected too. At 9" Diameter you start surpassing your SFM max in Carbide around 600RPM, so any faster and you're not doing yourself any favors.
  1. Copper to copper Welding
    By Masood in forum Welding Brazing Soldering Sealing
    Last Post: 11-19-2012, 05:10 AM
  2. Lathe Turning Copper Bar- HSS blank shape?
    By Odin in forum MetalWork Discussion
    Last Post: 04-06-2012, 02:15 PM
  3. Cutting Copper on a Lathe.... need input.
    By MychesterCNC in forum MetalWork Discussion
    Last Post: 09-11-2011, 03:07 AM
  4. * Polygon Milling beryllium copper cnc swiss lathe
    By TMW Mag in forum CNC Swiss Screw Machines
    Last Post: 09-26-2008, 12:14 AM
  5. copper?
    By bowhunter in forum MetalWork Discussion
    Last Post: 04-26-2007, 06:41 PM
