* NEW * Hitachi WJ200-075LF Variable Frequency Drive Inverter 10 HP 240v 3-Phase
This brand new VFD unit can drive an electric motor rated up to 10 HP when using 240v 3-phase power input. This unit can also be used with standard household 240v AC electricity, however in that case you can only drive a motor that is half as powerful (5 HP).
The output of this unit is always 3-phase AC even if you use single-phase AC as input, and the output voltage will be the same as the input voltage. The output amp rating is 33A CT / 40A VT. Most loads will be CT (constant torque), the VT (variable torque) rating applies to fans, pumps and other applications where the motor load scales exponentially with RPM.
We are selling a brand new WJ200-075LF in the factory box from Hitachi. It has never been used and it does include the Hitachi warranty.
List Date: 3/5/2016
For more info, click here to view the original listing: * NEW * Hitachi WJ200-075LF Variable Frequency Drive Inverter 10 HP 240v 3-Phase
On Sale For: $799.00
