585,925 active members*
3,466 visitors online*
    Oct 2011
    9
    2015 Mill Turn
    Set up the unit on the stand and powered it up today. Need to work out a few bugs with JT. The quality is actually a little better than I expected.
    Attachment 310954
    Mar 2016
    8
    Re: 2015 Mill Turn
    What bugs need to be worked out? I am thinking of buying. Have you machined anything yet?
    Oct 2011
    9
    Re: 2015 Mill Turn
    I am new to CNC machining have no idea were to start the documentation with Mach 3 is good but I need to learn from the start the documentation seems to be geared to someone with a basic knowledge of a CNC machine.I am taking a CNC Machine operators class at the locale Tech school but we are working on a Hass machine so it is beneficial but not the same. I have run the wizards and have had some results but still need to learn. I just downloaded the new NSF Wizard add on (free to license Mach 3 owners) it seems to be much more user friendly. If you u tube NSF Wizard you can see a demo. The construction of the unit is good fit and finish is good. I have not got into the fine tuning of the machine/program, that is way over my head at this time.
    The issues I had were some program and some of my own. Mach 3 and the mill directions were reversed and it was a matter of switching in the program. The one issue I don't like is when switching from Mill to Lathe the DRO readings don't change your axis's remains as if you were still in the mill mode. I was able to fix that by disabling the Y axis in the lathe program but 1 of the axis is reversed - and + reading . I was told by JT that I can change the - and positive on the DRO but have not researched that yet. I am considering making a switching box for the DRO activated by the Mill /Turn selector switch.
    JT from shop master has been great to work with, he has responded to my questions in a timely fashion even the dumb ones.
    Sorry it took so long to get back to you just checked my email
    Feb 2009
    180
    Re: 2015 Mill Turn
    Quote Originally Posted by EPaczkowski View Post
    Regarding the DRO, they have made a software change in 2017 so that with a push of a button, the DRO display switches from lathe to mill mode and eliminates that confusion over which axis to read. I don't think any other combo machine offers this feature. Documentation is much better now as well, with a lot of .PDF files on their website for this and the older machines going back 30+ years.
    Feb 2017
    7
    Re: 2015 Mill Turn
    Quote Originally Posted by jdclark View Post
    Pressing the EDM button twice changes the DRO from Mill axis to Lathe axis. It will say Lathe or Mill on the DRO when it changes.
  1. New 2015 Shopmaster Mill-Turn
    By Fiero Addiction in forum Shopmaster/Shoptask
    Last Post: 02-01-2016, 05:39 AM
  2. Mill Turn / Turn Mill / Multi Task C Y B Programming
    By aldepoalo in forum BobCad-Cam
    Last Post: 04-22-2015, 09:31 PM
  3. Mill Turn / Turn Mill / Multi Task C Y B Programming
    Last Post: 04-22-2015, 09:24 PM
  4. MachStdMill Turn and Mill-Turn Announcement
    By mvcalypso in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-16-2012, 03:38 PM
  5. Announcement: MachStdMill Turn and Mill-Turn
    By mvcalypso in forum News Announcements
    Last Post: 04-12-2012, 07:59 PM
