Turning question: I.D. ACME thread in Mori Seiki CNC lathe
I need to make a LOT of 1/2" thick ACME nuts with a 1/2"-10 thread inside it. Have you done this on a lathe and if so, what kind of tooling did you use? I want to avoid tapping it in my VMC if possible but I have literally spent dozens of hours over the past year not coming up with anything for tooling. It hasn't been a high priority up until now but in the next month I need to setup for testing and production. Ideally I'd like something with indexable carbide inserts but I could suffer with solid carbide tools if necessary. I know the cutting forces are much higher with ACME threads than conventional types of threads but I'm fairly certain I can work around that for my purposes. At this point my worst case option is going to Burchett tool, which is a high end custom manufacturer or endmills and cutters right by my house in Kalamazoo, MI and having tooling especially made but I thought I would ask her first.
I find it hard to believe there are not tool holders from Iscar or the like with indexable tooling but I do not find it hard to believe that I'e had a rough time locating said tooling~
EXIT 85 Manufacturing "The best custom wheels, period" (www.exit85.com)
Experts in low volume, highly complicated, one-off forged aluminum wheels
