I have a Tsugami BW12 lathe and I have a part that has a radius that gets milled across the part. I don't have any fancy program generators that can do the milling side of the work for this machine. I'm using a 1/16" end mill for this part, is it possible to just sketch a tool path 1/32" above the part following the geometry that way I can get my start and end points as well as the radius for the radius sketched. The radius on the drawing is .087in but when sketching above the part offset by .0312 for the tool my radius ends up being .0677. Is this a feasible way to do this or is there an easier way for figuring out radius's or arcs?
