585,752 active members*
3,748 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > CT40 vs. BT40 spindle's and tooling?
    Feb 2006
    37
    Total newbie question here.
    I'm about to purchase a Haas TM-1, and I'd like to know the difference between the CT40 and BT40 spindle's, and availability, and or desireability of tooling for them.
    In other words, which one should I get?
    Any help, or links, or suggestions, etc. will be most appreciated. Thanks! Joe
    Apr 2004
    88
    The differance between CT and BT is in the tool changer flange,
    and inch(CT) ,verses Metric(BT) threads for the pullstud/retention
    knob.
    CT is the american standard (first clue ) and BT is the Japanese
    standard. there is also a euro standard ,ISO
    As you live in the US CT is the way to go, every tool company
    will have CT wereas BT is often special order, and no doubt more expensive.
    The spindle of the machine as actually identical regardless
    of the Tool holder, CT,BT or ISO, what is differant is the tool change
    arm or carousel grippers (dependent on model).
    Functionally there is absolutely no advantage or disadvantage
    of any of the 3, just the ease of purchasing, and for you CT wins
    by miles.
    Feb 2006
    37
    CT wins!
    Thanks very much steveg for the excellent explanation! Joe
