Originally Posted by
Dugg
I've had some difficulties with chamfer tools in that I now input .062" for the tool tip and the same .062 for the tool diameter. I use tool comp with lead in and lead out, set the Z at -.035 and then use changes in the Z and D to get the edge I'm looking for. I'm sure there's an easier way, but I plod alone with what I know hoping to learn more.
Matts Method is a great way to achieve what you want. You can also go to the Manufactures website and get the specs on your tooling to help you. This way there is no constant running back and forth to the shop floor to measure tools that your going to use. All is good in the world of "WWW".
BTW: Keep using Cutter Comp so adjustments can be made for tool wear.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
