585,764 active members*
4,126 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Wasino Lathe with Fanuc 3T Feedrate is Zero
Results 1 to 6 of 6
    Mar 2016
    15
    Hi All
    We have a lathe wasino with Fanuc 3T.Be able to start up,go to zero,start machining,execute G00 but when hes coming to G01 he stopped and not move.
    I checked parameter and the feedrate is zero,but in a program is F100.
    No alarms on the machine,and the spindle is rotated also.
    May 2015
    70
    Quote Originally Posted by Brinmetal View Post
    Hi All
    If you're programming in feed per revolution, check the spindle encoder belt. If the encoder's not turning then your RPM's are 0 and your feed per rev will be 0 too.
    Dec 2012
    395
    Re: Wasino Lathe with Fanuc 3T Feedrate is Zero
    Change F100. to F100 or F0.1
    Regards,
    Heavy_Metal
    Mar 2016
    15
    Quote Originally Posted by Mike283 View Post
    Hi Mike
    I used to be machining before with this lathe,and there are no possibility to work with feed per revolution,only feed per time.(the feddrate override was inactive also)
    I try to put M48 M49 and maybe other codes(I dont remember now)and after this probes I go home.Next time when I switch in the machine,there is no feed anymore.
    You are agree with me,that is better to have regulation of a feedrate during the running,isnt?
    Arpad
    Mar 2016
    15
    Hi Heavy Metal
    I have machined before with simple F100 ,but of course I try F100. and F0,1 too,but when he coming to execute first line G01 he stopped.
    Jul 2011
    21
    does some body solved this problem. The dgn700.5 is 1=feed rate=0 on my machine to.
  1. Wasino CNC Lathe Parts
    By jptech in forum Want To Buy...Need help!
    Last Post: 03-26-2020, 04:32 AM
  2. FANUC 3T CONTROL ON WASINO LATHE
    By arolite in forum Fanuc
    Last Post: 07-31-2014, 04:30 PM
  3. Fanuc 5T controller/ Wasino Lathe
    By Motopsych in forum Fanuc
    Last Post: 02-07-2012, 02:56 PM
  4. Wasino Lathe
    By GoGuyG00 in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2011, 09:50 PM
  5. 087 Alarm on Wasino Lathe
    By Smrtman5 in forum Fanuc
    Last Post: 11-23-2010, 01:37 PM
