585,722 active members*
4,490 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Cheap,flat,sacrificial work holding fixture
Results 1 to 6 of 6
    Mar 2011
    480
    Thought this might be useful to others.
    I occasionally have the need to machine large (22" x 23") pieces of polycarbonate. I design the part with two locating pins centrally located so I can machine one half, rotate and do the other half while maintaining tight tolerances. In the past I have used MDF sheet stacked high enough for the tool to reach the part using those T slot clamping sets with all the pieces. I call them desperation clamps because hate fiddling with them, I have to be desperate to use them. Setup seemed to take forever. I came up with a quickly removable fixture plate using left over extrusion from my enclosure build as riser blocks. I drilled through holes in the extrusion, machines some t-nuts from aluminum and used two pieces of melamine shelving screwed together as the table. I counter bored holes deep enough for plenty of machining clearance on the 3/8" through bolts. I then machined some rocker clamps (?) from a 12" long strip of scrap aluminum. I machined slots and 3/8-16 threaded holes. Then cut into individual clamps using the band saw. I used 3/8" button cap screws upside down to serve as the rocker for the clamp, then drywall screws to clamp down the stock. I put an indicator in the spindle and was really pleased to see that I was getting .002" of flatness across the 22". After the machining was complete, part removed and the table still clamped down, I counter bored holes with a hand drill and ran some self tapping screws to captivate the melamine table to the extrusions. Now when I remove/install the table, everything is one piece. No loose fasteners. Just loosen up the 6, 3/8" bolts and slide the table off the bed with the T-nuts still attached.
    Aug 2007
    359
    Re: Cheap,flat,sacrificial work holding fixture
    I like it! Love to see more pics if you have them.
    Don't have to be too bright to be me
    Jul 2011
    400
    Very Nice. I recently had a job come through that although smaller would be a good match for this. I could put several on one pallet. thanks for taking the time to post this.
    Tom
    Mar 2011
    480
    Quote Originally Posted by mklotz70 View Post
    Sure..
    Attachment 312384Attachment 312386Attachment 312388
    Aug 2007
    359
    I'm a bit surprised that you can leave all 3 sets of T nuts on and still get it on and off the bed. Nice. Thanks for the pics!!!!
    Mar 2011
    480
    It does require little fiddling to get it on the table but it's way easier than my previous set up.
    Sent from my SM-G900T using Tapatalk
  1. Is there a standard size for work-holding fixture hardware?
    By FoxCNC1 in forum DIY CNC Router Table Machines
    Last Post: 03-14-2015, 03:27 PM
  2. need sacrificial material to work with vacuum table
    By hazelelectronic in forum Want To Buy...Need help!
    Last Post: 10-04-2013, 05:49 PM
  3. holding down larger flat plates
    By awetmore in forum Taig Mills / Lathes
    Last Post: 12-07-2010, 07:58 PM
  4. Advice on fixture holding needed...
    By kprice1658 in forum Tormach Personal CNC Mill
    Last Post: 09-11-2008, 12:25 AM
  5. Fixture for holding 31/32 Round Part
    By Smackre in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-03-2007, 02:24 PM
