585,931 active members*
5,517 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > WinCnc > L10 start somewhere other than the beginning?
    Mar 2016
    I'm using WinCNC with G-code and I have a question.
    I have a lot of production files that make many copies of something by using the L10 command, as in:
    (stuff to do first, like turn on the spindle, is here)
    L10 R10 C5 X4.250 Y2.175 E0 (MATRIX 10 X 5)
    (file content is here)
    L10
    (stuff to do at the end, like turning off the spindle, is here)
    In the example above, there are 50 copies (10 rows, 5 columns). Is there a way I can tell WinCNC to start at the 5th position of the 7th row?
    I need this because sometimes something goes wrong, and I have to stop the machine. I'd prefer to restart at the copy before the problem and then continue from there. Possible?
    Many thanks,
    Jim
    Mar 2008
    1762
    Re: L10 start somewhere other than the beginning?
    Jim...
    Sorry, but I know of no parameters or tricks to select a position in the array other than the first to restart from, but I will do a little checking.
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Mar 2016
    That is what I was expecting; I have read over the documentation quite carefully.
    I feel like I wouldn't be the only person looking for something like this; the more copies you run in a single file, the more likely you are to need a way to get past a fault during the run.
    With a bit of work I can create separate files that start at the beginning of a row or column, but it's impossible to start part way through a row or column and end up with all the desired positioned filled in. In a matrix with only 4 pieces in a row, it's not so bad to run back over 3 of them, but the more per row the less desirable this becomes.
    Is there a way to submit a feature request for WinCNC? It would be fantastic to see this added somehow.
    Many thanks,
    Jim
    Mar 2008
    1762
    Jim...
    When you say: "
    With a bit of work I can create separate files that start at the beginning of a row or column, but it's impossible to start part way through a row or column and end up with all the desired positioned filled in."
    You are exactly correct. Impossible.
  1. Beginning Mastercam Q&A
    By cadcam in forum Mastercam
    Last Post: 05-28-2012, 11:51 AM
  2. Back to the beginning.
    By LPEwing in forum Mach Software (ArtSoft software)
    Last Post: 03-17-2011, 01:55 AM
  3. N at the beginning of each tool?
    By gearsoup in forum Post Processors for MC
    Last Post: 11-20-2007, 03:24 PM
  4. At the very beginning
    By rackbox in forum DIY CNC Router Table Machines
    Last Post: 12-01-2004, 11:56 PM
