585,604 active members*
3,420 visitors online*
    Apr 2013
    20
    Question Mach3 ref all home not workin
    I have the limit switches working!!!
    The only thing I need to do is have homing
    I directed the homemach3.c in the config but no movement.
    few questions I have is
    1) Do you need to modify the Homemach3.c if so can I get an example on how to do that?
    2) Can I use a limit switch as my home switch?
    3) Do I need to setup or modify anything in Mach3?
    Besides this Kflop is awesome!!!!!
    May 2006
    4045
    Re: Mach3 ref all home not workin
    Hi Mac7988,
    Yes. The included HomeMach3.c only prints messages to the Console received from Mach3 to the KMotion.exe Console Screen. Are you seeing those?
    The first step is to figure out how to home your axes using KMotion.exe C Programs. Then once you have code that works for each of your axes merge it into the HomeMach3.c program. See the example SimpleHomeIndexFunctionTest.c
    Yes. The limits must be saved and disabled, then after homing and moving out of the limit they can be re-enabled. The SimpleHomeIndexFunction does this for you.
    Not normally
    HTH
    Regards
    TK
    http://dynomotion.com
  1. Home/Limit configuration in Mach3
    By ranju in forum DIY CNC Router Table Machines
    Last Post: 11-10-2012, 11:21 AM
  2. Home and limits in Mach3
    By m8298 in forum Mach Mill
    Last Post: 05-18-2012, 04:51 PM
  3. Mach3 + Home Switch
    By nexty5870 in forum DNC Problems and Solutions
    Last Post: 10-02-2011, 04:41 PM
  4. Replies: 1
    Last Post: 11-19-2010, 03:05 PM
  5. Set Home on Mach3 Turn
    By scot1972 in forum Mach Lathe
    Last Post: 03-12-2008, 07:46 AM
