585,712 active members*
3,857 visitors online*
    May 2014
    4
    Gerber 200 Dimension
    I have a Gerber 200 that I still use. But I'm ready to upgrade to something newer. I was wondering if anyone could give me an idea what the cost would be and how hard it would be to just upgrade this machine with newer parts or would it be better to just look for something newer. And if its more cost effective to buy new what would you recommend. Thanks Bob
    Aug 2009
    655
    Re: Gerber 200 Dimension
    Depends on the parts.
    Steppers and control would be fine and relatively straight forward. If you want to change the drive or gantry then its more work.
    I think it depends more on the value of your time, your budget, and your everyday needs (and why you want to upgrade). Maybe explain the what and why and you'll get some comments.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    May 2014
    4
    Thanks for the reply. There are a couple reasons why I'm looking to upgrade. The machine only runs on proprietary software, so to upgrade the software is expensive and I'm very limited on choices. Another reason is I had a couple problems with the machine and its very hard to find parts for it. I would probably not want to spend more than $6000.00 if I were to buy a newer machine. The machine is mostly used for private use not a business. Thanks Bob
    Aug 2009
    655
    OK so, let's break it down.
    Tell us what's OK or not :
    Size?
    Gantry height?
    Accuracy?
    Rigidity?
    Speed?
    Spindle /router power?
    Also what parts are hard to get, mechanical or electrical?
    For $6k, your at a good territory for a kit like from cnc router parts. But you likely have a better frame already.
    Replacing the electronics should be OK with enough work. Replacing the stepper motors (which I assume it is) is OK too and might even make the new electronics easier.
    New mechanical drive (like new rack and pinion), replacing chain or belt components, changing the Z height etc are all more project specific.
    Bottom line is if you are happy with the mechanics you'll be fine. I'm not a diy guy so I can't help but lots of people here can and have if you search.
  1. G & M Code on a Gerber Dimension 200
    By quaturbo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-16-2012, 01:15 AM
  2. My Gerber Dimension 200 router needs help!
    By markrobertsigns in forum Want To Buy...Need help!
    Last Post: 04-02-2010, 12:16 AM
  3. Looking for Gerber Dimension 200
    By gio666 in forum Community Club House
    Last Post: 06-01-2008, 03:32 PM
  4. Looking to buy a gerber dimension 200
    By gio666 in forum Canadian Club House
    Last Post: 05-27-2008, 08:39 PM
  5. Gerber Dimension 200
    By teemac in forum Gerber
    Last Post: 04-22-2007, 05:30 AM
