Originally Posted by
Devoreg
I am relativity new to using my laser cutter/engraver and I have just encountered a new issue. I have a 50W Chinese Laser and I just recently had to replaced the power supply. Everything was working great until last night I went to engrave a simple design that I had done several times before and rather than the laser pulsing on and off to burn into the wood it appears that the laser stays on and the image is engraved with only the outline shape. It appears to cut vectors correctly (I will test that more in the morning).
I do not know if the issue is in the software or hardware but I don't think I made any changes that would make this happen.
Attached 3 images that hopefully help explain my issue. The pics are the file i am trying to engrave, the result i am currently getting (I stopped the job mid way because it was obviously not correct) and the result that I have gotten in the past, engraved correctly.
If your advice is to not buy a cheap Chinese laser then please don't bother posting.
