585,898 active members*
5,195 visitors online*
    Mar 2004
    1306
    Building a Wiener90, Mendel90 derivitive
    My best man has been into 3D printing for year. He has a Prusa, and done really nice parts with it. He wanted something with a larger work envelope, and more rigid frame, so he took the Mendel90 design, learnt the software it was designed in, and changed basically everything. The result is the Wiener90.
    Wiener90 - RepRapWiki
    I hitched along for the ride, so whenever he printed parts for his, he generously printed an extra set for me.
    He built his frame from 25mm MDF, which is easily available in the UK. I went round four different hardware stores here in Vienna, but only found 22mm. The advantage is that the hardware stores are all set up with big wall sized sheet cutters, and sell you whatever size pieces you need, and you don't have to buy whole or half sheets. I messed up the two uprights, and went back and bought 2x 500x169mm and paid €2,30. Expensive for MDF, but cheap considering it is perfectly square, with sharp edges and on size.
    While both daughters are keen on the idea of a 3D printer, one got stuck in with laying out and drill the frame pieces.
    We've now assembled the frame, bogged the edges and screw heads, sealed it with a coat of shellac, and undercoated it. Once that dries, I am allowed to paint it pink
    Mark
    Regards,
    Mark
    Mar 2004
    1306
    Re: Building a Wiener90, Mendel90 derivitive
    If you employ child labour, don't let them usurp the role of artistic director.
    Attached Thumbnails Attached Thumbnails WP_20160321_21_35_23_Pro[1].jpg   WP_20160321_21_35_28_Pro[1].jpg
    Regards,
    Mark
    Mar 2004
    1306
    Woops, forgot to document most of it. It is now up and running with a DuetWifi. After the initial test peices of Unicorn cookie cutters and mermaids, I printed of some parts for the pattern of a casting I need to make for my other never ending project...
    http://www.cnczone.com/forums/bencht...ml#post2059966
    Since this machine is a copy of the one my friend made, I just copied all his set up files and it works great.
    Regards,
    Mark
  1. Building my own CNC
    By Ridwan in forum Xylotex
    Last Post: 03-09-2012, 11:46 AM
  2. Building my first CNC!
    By IWorkInPixels in forum DIY CNC Router Table Machines
    Last Post: 11-19-2010, 05:49 AM
  3. Building Joe's '06
    By bkboggy in forum Joes CNC Model 2006
    Last Post: 04-21-2009, 08:26 PM
  4. help with BUILDING a cnc
    By MBG in forum Mentors & Apprentice Locator
    Last Post: 02-19-2008, 11:11 PM
  5. building my own
    By bean7795 in forum Benchtop Machines
    Last Post: 06-22-2004, 04:24 PM
