585,759 active members*
4,290 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > BCAMCNC 9060 machine with horrible defects
Page 1 of 3 123
Results 1 to 20 of 44
    Feb 2016
    38
    In November 2015 I ordered a 6090 3 axis mill from BCAMCNC. 3rd of january 2016 the machine was delivered, after a delay because they said the truck had an accident while moving the machine to the sea port. They said I will get a new machine but what I unpacked was definitely a machine that had an accident. Until now (end of march 2016) their only offered solution was to sell me a second machine at a small discount which I have to pay in advance.
    Is there anyone having similar problems with them?
    I will post here the defects of the machine day by day since its 40+ defects.
    Feb 2016
    38
    Re: BCAMCNC 9060 machine with horrible defects
    First of all lets have a look on the exhaust system:
    Attachment 313552
    Attachment 313554
    Attachment 313556
    Attachment 313558
    Attachment 313560
    Attachment 313562
    Attachment 313564
    Attachment 313566
    Attachment 313568
    Attachment 313570
    BCAMCNCs first answer was, that this is the fault of my shipper but the outer box was completely fine. So in my opinion this is just wrong packaging from BCAM.
    What do you think?
    Feb 2016
    38
    Here is a view of the table. Please remember that I ordered a new machine not a refurbished or used one:
    Attachment 313572
    Attachment 313574
    Feb 2016
    38
    This is below the table. It seems like there was a small gap and the solution of BCAM was not to fix the table alignment, but to stuff something into the gap making it even bigger. Now the table is 1cm higher at this point than at any other point of the table. It is nearly impossible to get this out because they glued this in.
    Feb 2016
    38
    This is the curtain. BCAM claims to offer high quality but it looks like they even can not handle scissors...a 3 year old child can do better
    Feb 2016
    38
    Many screws are squeezed into poorly cut threads, damaging the screws and the threads. It is not possible to put a screw correctly in there.
    Feb 2016
    38
    This is how most of the covers look like:
    Feb 2016
    38
    Then lets have a look at the screwholes they made....they should be round and this is what they look like:
    Feb 2016
    38
    So I think this was enough for one day. To be continued tomorrow.
    I hope someone from BCAMCNC will reply to this. I know they are active in this forum so this is their chance to make it right.
    Feb 2016
    38
    So lets continue this.
    Here you can see the rails of the machine, they are covered in metal chips and it is very likely that metal chips are already inside the bearings:
    Attachment 313694
    This is the electronics compartment covered in metal chips, I think some of these chips already went in the controller through its venting holes:
    Feb 2016
    38
    This is also a rail of the machine. It was painted!
    Attachment 313698
    Here is another part of the paint job. The electronics were painted too:
    Attachment 313700
    It looks like they attached the exteriors and painted over it:
    Feb 2016
    38
    Here it seems like they had not enough paint left:
    Attachment 313704
    Fun Fact: The emergency stop does not cut off the power of the machine. It only stops the movement of the motors.
    More pictures of this paint job:
    Attachment 313706
    Here they had not the right paint on hand and had to use three different green (Please remember they claim to offer high quality and I bought a brand new machine from them):
    Attachment 313708
    Attachment 313710
    Feb 2016
    38
    This is also a nice one:
    Attachment 313712
    The machine goes on when you switch to "Off" and it goes off when you switch it on
    Feb 2016
    38
    They also did not deliver any machine or controller manual, No filter bag for the exhaust system and the compressor for the coolant spray was also not delivered.
    Feb 2016
    38
    There is a screw and I can not find where it belongs:
    Feb 2016
    38
    I found a thread cutter near the rails, blocking one axis:
    Feb 2016
    38
    This is a bearing below the table. You can see how much metal chips are building up at the bearings. It will take only a short time until this bearing dies:
    Again, please remember this is a unused machine!
    Feb 2016
    38
    One axis is somehow loosing steps:
    The oil system is leaking:
    Feb 2016
    38
    Another big problem is that I asked many times before purchase if this machine fits through a 90cm door and always their support said that it will fit.
    When the machine was delivered it was 110cm wide! So it is not going through the door and I since have to pay warehouse fees to have it stored until I get a solution from BCAMCNC.
    One offered solution was that I should tilt the machine by 90 degrees and try to get it in this way. The machine has nearly 600kg!! So I think they just made a joke.
    They say that they have a ISO9001 certification but I wonder how such a machine can be delivered with a quality assurance system like ISO9001
    Dec 2014
    19
    That's terrible - Thanks for the pictures, they'll never get any business from this board...
    In this situation, lying about a 9001 cert would be better than actual compliance. 9001 is not so much about controlling quality, as it is ensuring consistency through documentation and process control. Scary if this is an example of SOP.
Page 1 of 3 123
  1. logilase 9060
    By woodman08 in forum LOGILASE Laser
    Last Post: 02-10-2022, 08:12 PM
  2. defects to make a circle
    By Peruanzon in forum ArtCam Pro
    Last Post: 05-05-2015, 02:45 AM
  3. Borsh 9060 from cncdiy.org
    By kiwichris in forum Chinese Machines
    Last Post: 07-22-2011, 05:35 AM
  4. Any advice on mod to Rabbit 9060
    By dvdlock in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-24-2009, 10:11 PM
