585,717 active members*
4,206 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0iMD - Error 5139 FSSB Error
    Dec 2006
    310
    Dear Sir
    Error 5139 : FSSB Error
    We have followed following procedure :
    Bit 0 & 1 of Param 1902 made 0, , Param 1023 for X,Y,Z & B is 1,2,4,3 respectively, Initial set bits of X,Y,Z,B changed to 1, switched OFF and ON
    FSSB – Amplifier…. Under Axis column, Inputted 1,2,4,3…..pressed Setting
    FSSB – Axis, inputted 0 under M1,M2,IDSP,Cs & TNDM in all rows, pressed Setting and finally 1902 bit 1 found 1 , pressed Setting to complete
    Now under FSSB screen, Amp against all SVMs etc found correct
    But now getting Error SV0456(X) : Illegal Current loop
    Kindly advice
    Regards
    Dec 2006
    310
    Re: Fanuc 0iMD - Error 5139 FSSB Error
    Quote Originally Posted by M.RISHIKESH View Post
    Dear Sir
    Kindly advice
    Regards
    Dear Sir
    We could fix this error
    Actually power LED on SDU1 was sometimes blinking breaking FSSB, as we dont have similar SDU1 with us at the moment, we did FSSB initialization then bypassed external feedback to run axes with Motor encoder, machine is OK now
    Warm Regards
  1. Fanuc error 998 ROM Parity Error ???
    By ED209 in forum Fanuc
    Last Post: 02-07-2022, 10:02 AM
  2. Fanuc 0iMD - Illegal Macro sequence error
    By M.RISHIKESH in forum Fanuc
    Last Post: 12-10-2015, 12:31 AM
  3. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
  4. Replies: 0
    Last Post: 05-05-2013, 05:40 AM
  5. Fanuc 0iMD - 1960 access error(memory card)
    By ddanutz1 in forum Fanuc
    Last Post: 01-17-2013, 07:51 PM
