585,917 active members*
3,508 visitors online*
Results 1 to 13 of 13
    Sherline 50173 - Leadscrew
    50173 - Leadscrew, 18", CNC, X-axis (inch)
    Product #: 50173
    Price: $42.00
    Forty two fscking dollars for 18" of threaded rod!
    Does anyone know a cheaper source? This is just 1/4-20" threaded rod with a hole drilled and tapped right?
    Mar 2012
    109
    Re: Sherline 50173 - Leadscrew
    Feel free to use standard threaded rod for it. Get back to us when you realize that a leadscrew has certain quality standards that end up costing money.
    Quote Originally Posted by inthebay View Post
    We're talking about a Sherline. It's just threaded rod.
    The normal-travel (12"?) leadscrew is $19.
    50171 - Leadscrew, CNC, X-axis (inch) $19
    The Y axis Leadscrew is the same.
    56160 - 2000 Mill Leadscrew, Y-axis (inch) $19
    There is also this
    67026 - Leadscrew, CNC, 24" (inch) $31.50
    The 18" leadscrew for the extended bed, FORTY-TWO DOLLARS!!!.
    What's up with that?
    Feb 2007
    4553
    Unhappy Re: Sherline 50173 - Leadscrew
    Quote Originally Posted by NCSProducts View Post
    There is also this
    In there defense "Roton" the manufacture of 1/4-20 leadscrew charges $18.00 per foot ($27.00 for 18" plus shipping) so forty two dollars is not that much of a markup.
    1/4 - 20 Right Hand Acme Lead Screws & Nuts for Power Transmission - Roton Products, Inc.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2004
    5737
    So just order the stock from Roton, and take it to your local machine shop so they can turn it down on the end and drill it. I'm sure you'll save a ton of money...
    Andrew Werby
    Website
    Feb 2007
    4553
    Quote Originally Posted by awerby View Post
    Andrew,
    Please clarify - Would that be metric tonnes, short tons or imperial long tons?
    Jeff...
    Jun 2006
    3063
    More like lunar very short tons.
    Nov 2009
    4415
    Dont forget the taper to match the Sherline couplers ;-)
    A lazy man does it twice.
    Jun 2006
    3063
    Quote Originally Posted by Fastest1 View Post
    That's nothing that a little quick work with a Dremel and a carbide burr couldn't fix right up.
    Nov 2009
    4415
    Quote Originally Posted by MichaelHenry View Post
    That takes time, time is money. Furthermore the taper wouldnt be very accurate and would slip and or break.
    I never did like that design anyway. Easier to bore and thread the coupler and use all thread.
    Mar 2007
    304
    Actually - the Sherline threaded rod is also hardened... So its not just a simple piece of all-thread. However, I really think the area that needs improvement is the nut. It is pathetically undersized.. and they reailly need something like a nut 1" long with some better anti-backlash features. (like a dumpstercnc anti-backlash nut or something)
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Jan 2007
    175
    We retrofitted a few of these sherline mills for 3D printing to 1/4- 4 start, with dumpstercnc couplings, made a huge difference with speed and accuracy,
    Here's some info,,,,,,,,, Sherline Mill
    Now that I look back, I think the original screws were Left hand, so this could be why they cost more?
    Rockcliff Machine Inc.
    http://www.rockcliffmachine.com
    Nov 2009
    4415
    The mills have much more room than the lathes.
  1. Leadscrew cover for your Sherline mill
    By chuck.yeo in forum Benchtop Machines
    Last Post: 03-03-2019, 01:17 PM
  2. Replies: 1
    Last Post: 03-29-2016, 09:49 PM
  3. 9 x 20 Leadscrew
    By jroma1 in forum Mini Lathe
    Last Post: 03-05-2008, 11:46 PM
  4. Leadscrew?
    By bearwen in forum Commercial CNC Wood Routers
    Last Post: 03-03-2006, 01:24 PM
  5. Acme leadscrew or Trapezoid leadscrew is better?
    By minicnc in forum DIY CNC Router Table Machines
    Last Post: 03-07-2005, 06:57 PM
