585,997 active members*
4,942 visitors online*
Results 1 to 6 of 6
    wagnerskis Guest
    Just got 2 Exitech machines, might sell
    Hi, I work for a custom ski manufacturer in Colorado. We just got 2 Exitech machines from a ski manufacturer in China but are not quite sure if we want or need to keep them & are trying to understand the value of the machines in case we want to sell them. The machines are Exitech 1325a, they each have 4 spindle routers. I am wondering if there may be anyone on the forum who could give us a ballpark estimate of the value if I were to post some photos & more info.
    Many thanks, Cormac.
    Apr 2004
    475
    Re: Just got 2 Exitech machines, might sell
    Depending on what the spindles are, my guess is 9-15k new, $US (I'm in Canada), deprecate according to condition, and know that it's probably not too common of a configuration.
    Sent from my ASUS_Z00TD using Tapatalk
    wagnerskis Guest
    Thanks, much appreciated info.
    Feb 2016
    381
    Sounds like the generic 1300x2500mm machines sell at $4000-4500 single spindles so think other guesstimate a little high.
    Dec 2007
    2134
    If they each have 4 spindles, you may have some luck with companies doing turning work, as these machines are commonly used for newel posts and balusters.
    Door companies would also use them for carved door inserts.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Apr 2004
    475
    My estimate was for a cheap servo system, DSP controller, steppers and mach3 could be less, I agree but a commercial machine is probably better that the $5000 machines with extra spindles.
  1. Sell Haas Machines - KS, MO, or IL
    By NYMAT in forum Employment Opportunity
    Last Post: 05-16-2013, 07:23 PM
  2. Need a factory rep. to sell proprietary scanners / milling machines.
    By neogroup in forum Employment Opportunity
    Last Post: 06-14-2012, 03:10 AM
  3. Anybody build machines to sell?
    By Gaz. in forum Want To Buy...Need help!
    Last Post: 07-28-2011, 07:03 AM
