585,728 active members*
4,320 visitors online*
Results 1 to 10 of 10
    Jun 2013
    12
    Converting simple DXF file to tool path G code
    I've used NC Plot successfully to generate tool paths by converting DXF files to g code. But today I have found a stubborn problem with this feature of the program.
    I have a 3 inch circle I'm milling and I have a short lead in and lead out for a good finish. These leads are little arcs about 100 thou long. When NC Plot converts the DXF file to G code it always starts with the circle, then one of the leads, and then the other lead in or out. There must be a way to select the proper order but I can't figure it out. I've read the manual and used trial and error extensively to no avail. Anyone using NC PLot for DXF converting? How do you control the tool path order?
    Jan 2009
    103
    Re: Converting simple DXF file to tool path G code
    NcPlot converts in the order the geometry is created in. If you create the lead-in arc on the first layer
    followed by the 3 inch dia.circle on the second layer then the lead-out arc on the third then export, you
    should get what you want. To verify this, type in the following in NcPlot:
    G0X1.4Y-.1Z0
    G3X1.5Y0J.1
    I-1.5
    X1.4Y.1I-.1
    Then export DXF and import DXF back in, you'll notice the geometry will be in the same order as coded
    hope that helps
    Jun 2013
    12
    Your example worked just as you described. I am using DXF files generated with Sold Works though. I'm not certain how to create my geometry on different layers.
    When I export a DXF file I have the option to select Views to export and I believe I have seen multiple layers when I have messed with exporting all the views.
    May 2007
    37
    Did you try already to chain during import ?
    Richard
    Jan 2009
    103
    In Solidworks if you create three sketches, first sketch (lead-in), second sketch (circle), third sketch (lead-out) then you'll get what you need.
    Jun 2013
    12
    Quote Originally Posted by mcode View Post
    I gave that a try just now and it didn't work. All the sketches were put on the same layer. I'm looking into layers, it seems if i could just get each arc on a different layer I'd be golden. I think i was able to create a multi layered DXF file by selecting all views while saving the file as a DXF. I could possibly move each arc to a different view but that's a bit tedious. I'm also going to experiment with different DXF formats while saving my DXF files.
    Jan 2009
    103
    Not sure why it didn't work for you, I did it before I posted a solution. My file has 3 sketches in the project tree that have the individual entities in each sketch, when exported for NCPlot it worked fine and the path can also be reversed using reverse chain while Importing. The 3 individual sketches are like having 3 layers with a sketch on each layer. When creating the geometry make sure they are defined correctly. hope it works for you
    Jun 2013
    12
    I wonder what version of dxf file are you exporting? I was using setting R2013. NcPlot was always starting my circle at the 3 o'clock position as well. How did you draw your circle in Solid Works? I started at the middle and then clicked the 12 o'clock position. Thanks for your help.
    Jan 2009
    103
    I'm using the latest SolidWorks, I created the circle the same except snapping on the first sketch arc end point, if you set the first sketch to show then you can snap to it. Just curious, are you using a part file or drawing file?, I'm using a part file.
    Jan 2009
    103
    SolidWorks may not be the best way to get what you want, DraftSight, which is a free software from Solidworks does the job well, it's similar to AutoCad and is easier to control start and end of the geometry. I was easily able to export to NCPlot with expected results, all on same layer, if on different layers NCPlot imports as non continuous tool path
  1. converting a solidworks file to g-code
    By JoeyB in forum Australia, New Zealand Club House
    Last Post: 05-15-2015, 11:53 PM
  2. Replies: 1
    Last Post: 09-09-2011, 01:23 AM
  3. I need a very very simple g-code file please.
    By Ranscon in forum G-Code Programing
    Last Post: 09-03-2009, 12:13 AM
  4. tool path from stl file?
    By Tristar500 in forum 3D Printing / Scanning Software and Hardware
    Last Post: 07-23-2009, 02:18 AM
