Re: 3D toolpath strategy ( approach) advice !!
Originally Posted by
Robert M
BTW,,,,what you mean by....."ballnose tend to cut lousy when cutting near the center of cutter" !!
Why lousy ?
Later
They cut lousy right at the tip because the cutting speed drops to zero or near zero. Also, where the flutes come together at the tip generally does not provide much if any cutting surface, or area for chip evacuation. A bullnose endmill has some flat on the bottom, like a regular square mill, so it is better suited to cut flat surfaces.
If it is machining the underside (at least in verify) you need to be limiting your cutting area either with check surfaces or containment boundaries.
____________________________
My blog: http://www.fletch1.com
