Re: Any way to get more torque out of the 770 spindle motor at low RPMs?
You could always just replace the low range pulleys so either the one on the motor is a smaller diameter or the one on the spindle is a larger diameter.
The only repercussions of that is that it would eliminate some of the overlap between low and high range.
You would also have to figure out how to edit PP config file to adjust the reduction ratio.
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
